Old 09-24-2015, 02:33 AM   #1
GMJimmy
Lowering shocks
Hi all.
I recently traded my 70 SWB step side for a 68 SWB fleetside that the previous owner lowered 3 inches in front and 2 inches in the rear. The rear shocks need to be replaced because they are damaged (looks like they may have been installed upside down at one point) and the fronts look like they only have about 1-1/2 inches of travel before bottoming out. What's everybody using for shocks on these lowered trucks? Any suggestions are greatly appreciated.
Jim
GMJimmy is offline   Reply With Quote
Old 09-24-2015, 06:53 AM   #2
PGSigns
PGSigns's Avatar
Re: Lowering shocks
I have these and really like them.
Jimmy
Amazon.com: Belltech 9547 Street Performance... Amazon.com: Belltech 9547 Street Performance...
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-24-2015, 01:18 PM   #3
69gmcc10
69gmcc10's Avatar
Re: Lowering shocks
allot of vendors here sell shock relocation brackets to help bring the shocl back to a more vertical position and there are even a few treads on the forum that show how to make your own. With the rear being lowered and you are replacing the shocks you may want to think about doing this as well.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 09-24-2015, 03:59 PM   #4
GMJimmy
Re: Lowering shocks
Thanks for the replies. I was hoping there was some info on some vendors selling shocks specifically for lowered trucks.
Old 09-24-2015, 06:19 PM   #5
69gmcc10
69gmcc10's Avatar
Re: Lowering shocks
Out back I would relocate the mounts an keep stock height shocks if it is only 2" lower. In the front (I am assuming the lowering is from shorter or cut coils due to the limited travel you mentioned) I would call Early Classic and get a set of KYB lowering shocks.
Old 09-24-2015, 07:58 PM   #6
SoCoC10
SoCoC10's Avatar
Re: Lowering shocks
Jim here's what I used for my 67 that I dropped 4" in the front and 5" in the rear. I paid less than $65 for all four KYB shocks. Truck rides great even with 20" rims on it. I'd try just the shocks 1st then get the rear shock relocaters it you think the ride it too bouncy. Hope this helps.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 09-25-2015, 02:47 AM   #7
GMJimmy
Re: Lowering shocks
The front is lowered by drop spindles. Not sure the shock travel is normal or not? Maybe there is only 1-1/2" of the chrome shaft visible in a stock application?? I think the back will handle stock shocks as you suggested. Is there a relocation kit available or would I have to fabricate some?
Thanks for the link! I've used KYB shocks in the past and found them to be very good. I'll give them a try for the truck.
Thanks everyone for the replies.
Old 09-25-2015, 10:38 AM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Lowering shocks
If you only used front dropped spindle, nothing in the suspension travel has changed. You would use stock length shocks.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-25-2015, 11:58 AM   #9
69gmcc10
69gmcc10's Avatar
Re: Lowering shocks
Absolutely, Get stock height shocks all around. KYB and Monroe Sens-a-trac are awesome and affordable options!
Relocation kits are available from Early Classic, CPP, and other vendors. SoCoC10 is on to something though, swap shock first and then, if it is till too soft for you use the relocators.
