Old 09-24-2015, 02:19 PM   #1
solidaxel
solidaxel's Avatar
LM 7 Run sensors
I just purchased a 5.3 and would like to start it
What sensors are required to just start the engine
I do have the TAC and peddle and a new computer that has had the VSS removed and tuned
Do I need to add ALL the sensors to start minus the Evap?
Cam, crank, water temp.???
What should a good/fair engine have for compression?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-26-2015, 01:08 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LM 7 Run sensors
Hookup the MAF and the front 02's also (even if they just are in an open header pipe), knock sensors, cam and crank sensors all need to be in for an easy start. Coolant Temp and Oil pressure aren't 100% needed to run, but you really should have them hooked up so they can be monitored on that first start/run.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-27-2015, 11:55 PM   #3
solidaxel
solidaxel's Avatar
Thanks Br3W
OK I have all of those mentioned,
Now to sort the switched and 12VDC and grounds
LS 3 4L70E
