Old 09-24-2015, 03:27 PM   #1
forestb
forestb's Avatar
62 rear shock relocation brackets
Does anyone sell shock relocation brackets for a 60-62 or do I need to make my own?
forestb is offline   Reply With Quote
Old 09-24-2015, 04:38 PM   #2
forestb
forestb's Avatar
Re: 62 rear shock relocation brackets
Also should I get front shock relocation brackets if I have 2 inch drop coils and 2 inch drop spindles?
Old 09-25-2015, 12:33 AM   #3
Captainfab
60-66 Nut
I believe you will have to fabricate your own rear brackets. I'm not sure if the '63-'72 front shock brackets will work on the '60-'62's.
Old 09-25-2015, 01:06 AM   #4
joedoh
joedoh's Avatar
drop spindles move the wheel center up in relation to the rest of the suspension so the effect is "invisible" to shocks, only the 2" drop coils are "visible" to the shocks, so your total drop at the shocks is 2", and its been said the stock length shocks will handle that drop.
mcgaughys sells rear extenders, they are pretty universal for rear shocks and I would bet a donut they could be flipped over and modified for the upper front mounts too.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-01-2015, 01:55 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Any progress on this?
60-62 Rear shocks relocation brackets?
66 C20 Service Truck:
Old 11-02-2015, 01:11 PM   #6
forestb
forestb's Avatar
I think I am just going to move the old mounts further forward. While taking the rear end out I noticed that my shocks are to short and are probably over extending. Moving the shock should help solve that problem.
Old 11-02-2015, 01:31 PM   #7
LostMy65
LostMy65's Avatar
Yeah, there's something weird with mine.
Somebody put air shocks on it, and I have to keep them pumped way up to a stiff ride to keep my wheels from rubbing on the fenders. I think if I move the upper shock mount forward, it'll give a more upright position to the shocks.
Old 11-02-2015, 06:24 PM   #8
wilbur46
wilbur46's Avatar
Check in the FAQ section, or look thru the builds.
POL and Classic Industries both have them. $3? plus shipping ??
I just used 2" square tube a saw and a drill.
I have a static drop of 5", so I moved the mounts back (and they go up a little) until they were at about a 15 degree angle, then drilled the tube for the stock frame holes. TA-DA!
(You need a few washers to center the shock)
By the way, after grinding the rivets off and removing the stockers, I think they will be good for replacing the frront mounts!
W
wilbur46 is offline   Reply With Quote
Old 11-02-2015, 07:06 PM   #9
verdell
verdell's Avatar
Thinking of doing the same thing for the rear. I ran across two spare shock mount bolts that came with the last pair of shocks I bought and I'd like to make these work. Just waiting on the rain to pass on thru. I think I finally have the fronts situated, just need a better quality shock...I hope...
verdell is offline   Reply With Quote
