Old 09-24-2015, 05:23 PM   #1
chastain90
chastain90's Avatar
Big Block Question
I am considering a big block in my 72 blazer. After researching I believe I will move the engine mounts forward 1 1/2 inches according to what everyone says to avoid the firewall clearance problem. My question is, I have a SM465 4 speed and wonder what will have to be done as far as clutch linkage placement? Will I have to modify anything else for this to work besides the cross members and driveshaft being lenthened?
Thanks for any help
chastain90 is offline   Reply With Quote
Old 09-24-2015, 05:45 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Big Block Question
If you move the engine forward the linkage will definitely be effected. Your front driveshaft may need to be shortened. It's angle will become a little steeper too.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-24-2015, 06:06 PM   #3
chastain90
chastain90's Avatar
In that case would it be better to just do the firewall clearance?
Old 09-25-2015, 11:16 PM   #4
colgad
colgad's Avatar
I believe the bellhousing mounts are effected also.
I would work on the firewall if there are clearance issues. I had at one time a stock 71 with a 402 and didn't have any clearance issues
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 09-30-2015, 05:29 PM   #5
kehstr
kehstr's Avatar
you will probably just be better off to buy an nv 4500, sm465 don't hold up to big blocks very well, telling you from experience
kehstr is offline   Reply With Quote
Old 10-01-2015, 05:03 PM   #6
cleszkie
cleszkie's Avatar
I gotta admit, that is the first time I've ever heard someone say the SM465 won't handle a big block. If an SM 465 won't do,then neither should the NV 4500, as it is basically an SM 465 with an overdrive. What kind of horsepower/torque were you making when you took your SM 465 out?
cleszkie is offline   Reply With Quote
Old 10-01-2015, 05:26 PM   #7
kehstr
kehstr's Avatar
they actually aren't even close to the same. The nv4500 up to about 1998 when the nv5600 came was the strongest manual trans. The nv4500 has gears that hold up to a lot more. The input shaft is the thing that normally goes on the sm465, and when they go, everything on the trans goes. The input shaft on an nv4500 is larger, i couldn't tell you how much larger, but i do know that they are larger. My motor could have been able to hold up to it, but i saw one that went when it just have 450 horsepower and about 370 foot pounds. I was planning on running a little bit more when i was building mine, and i decided that it wasn't worth the hassle, so bought an nv4500 to not have to deal with it
Old 10-01-2015, 05:46 PM   #8
kwmech
I guess GM messed up when they put a 465 behind a 427 then put it in a 2 ton truck
Old 10-01-2015, 05:49 PM   #9
kehstr
kehstr's Avatar
yeah those 465 didn't hold up for very long at all. Unless someone at one point put some 5.13 or lower gears in it, then the trans at least lasted a little while, but still weren't very strong
Old 10-01-2015, 08:41 PM   #10
kwmech
That's called sarcasm. I've got a 465 in my 3/4 ton that I work a lot and a 465 in my 1 ton wrecker, never had a problem with either one, AND I rebuild quite a few with different mainshafts and such and never seen a major problem except in the early ones where the countershaft just had a snap ring holding 3rd gear in place, all it takes is a solid spacer, done
Old 10-02-2015, 12:18 AM   #11
chastain90
chastain90's Avatar
So can anyone tell me what has to be done exactly on the big block swap with the 4 speed? I would like to see what has to be done to the linkage from someone who has done it
Old 10-02-2015, 02:14 PM   #12
Lieferson
Lieferson's Avatar
put a 2" body lift on there if you want some extra clearance. it may just fit in there though, same trucks but they are all different. best bet is trial and error. might get lucky.. just my .02
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 10-02-2015, 03:18 PM   #13
1rippen6
I went from a small block to a big block years ago the only thing I remember having an issue with was the distributor to firewall clearance but I was running a 350 turbo. I never moved the crossmember and if I remember right I just removed the motor mounts from the SB and bolted them to the BB.
1rippen6 is online now   Reply With Quote
Old 10-02-2015, 05:31 PM   #14
chastain90
chastain90's Avatar
Thanks but even with the body lift wont the clutch linkage have to move?
Old 10-07-2015, 01:25 AM   #15
'63GENIII
'63GENIII's Avatar
The comments about the 465 really made me do a double take for a minute. TBH, I really like my 4500 over the 465 for drivability, but IMO, the 465 is a stronger trans in stock form. My 4500 has made a few "noises" that I never had with the 465. Mainly bearing noise and the occasional "Halloween noise" as my son calls it. I drive that trans as if it would cost 2 - 3k to rebuild. On the other hand, the 465 always seemed to get abused and I didn't give it a second thought.
If I really wanted a 5 spd that could withstand power / abuse like a 465, Id look for a NP540 or a Clark 5.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-07-2015, 02:52 AM   #16
chastain90
chastain90's Avatar
After further thought I may stay with the 465 if I can move the engine forward and make my clutch linkage work.
Old 10-19-2015, 06:28 PM   #17
SleepyK5
I went with nv4500 with hydraulic clutch setup works great. I'm pushing 575HP and 550 torque through mine. Hope my 12" holds up!
SleepyK5 is offline   Reply With Quote
Old 10-20-2015, 11:59 AM   #18
kehstr
kehstr's Avatar
if the 12 bolt does go, an easy thing to do, is to put a 6 lug 14 bolt out of a 88-98 Chevy or gmc pickup, I've seen them hold up to lots more torque, and tons of abuse, and are still working
