Old 09-25-2015, 04:29 PM   #1
ivorton74
ivorton74's Avatar
Idle relearn for DBC 5.3?
So I'm still having the idle hunting issue with my truck and it's irritating me really bad now. I tried cleaning the throttle body, replaced the iacv and tps. Today I tried swapping out the throttle body with one from another '99 5.3 and its still hunting so my buddy is thinking maybe we have to do an idle relearn but we don't know if we can do it on a DBC engine. Can anyone tell me if this can be done?
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 09-25-2015, 07:35 PM   #2
homemade87
Re: Idle relearn for DBC 5.3?
The idle relearn that gm suggest has nothing to do with cable or wire throttle body. Works the same Several heat cycle does it also. Just take a little longer . You may try cleaning the mass air . It can also affect things .
You have provided no info on any mods if any . There is a lot of things that can affect this . If some mods have been made you will most likely have to get a tuner to look at it .
homemade87 is offline   Reply With Quote
Old 09-25-2015, 08:05 PM   #3
aknovaman
Idle learn is for drive by wire. It learns where the pedal is at closed throttle and where it needs to open the throttle to obtain commanded idle speed.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 09-25-2015, 08:16 PM   #4
homemade87
Not true , The ecm has to learn the position of the iac position to control idle , which the drive by wire does not have.
Old 09-25-2015, 08:27 PM   #5
aknovaman
Iac learn is for dbc and idle learn is for dbw.
http://youtu.be/NAnEoMa80VY
http://www.gm-trucks.com/forums/topi...ottle-relearn/
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
IAC Relearn Procedure
If you are having idle issue you may need to reset your Idle Air Control (IAC) and
TPS, do this before you start drilling holes in your throttle body (TB) blade. I have
used this procedure on some huge cammed cars and it worked.
1) Monitor your IAC, Idle Speed, throttle position voltage and your throttle position %.
2) With the key in the ON position, adjust your TB set screw until your throttle position
is 2%.
3) Turn your key to the OFF position.
4) Unplug your Throttle Position Sensor (TPS) and IAC.
5) Turn your key to the ON position for a few seconds, and then OFF again.
6) Plug in the TPS and IAC and then turn your key to the ON position and restart
logging. Your throttle position will now be reset to 0 degrees and about .45-.55 volts.
7) Start your engine, your IAC should be 40-60 for a cammed engine.
if you are not at your desired IAC position redo the above procedures in smaller
increments.
FMCDH GBU and GBA
Old 09-25-2015, 10:30 PM   #6
ivorton74
ivorton74's Avatar
@homemade87...the engine is bone stock. I cleaned the maf sensor and it works just fine.
@aknova thanks man I will try that and see what happens. u said the iac for a cam should be 40-60?? volts or what??
Old 09-26-2015, 06:48 AM   #7
aknovaman
Iac counts on scanner.
FMCDH GBU and GBA
Old 09-26-2015, 12:14 PM   #8
ivorton74
ivorton74's Avatar
ohhh ok thanks
