Old 09-25-2015, 10:52 PM   #1
groundbound64
Raised tilt bed floor info/pics/suggestions
Hi all,
I'm currently building my raised bed floor. I'd like to have it tilt up at the tailgate to make easier access to air management and to show it off alittle. Any of you done this before ? if so, would you have any pics or suggestions to share. Can't decide on how i'm going to make it "tilt" . Thanks in advance.
64 C10 Stepside 350/4psd Driver/Project on air.
Dom bags, Dual Viair and AccuAir
08 Ford F150 Limited- F-word ! Daily Driver
.......................____
..........._______l/ \____
...........|_/(0)\_ll____/(0)_l.
groundbound64 is offline   Reply With Quote
Old 09-26-2015, 12:12 PM   #2
dougf
dougf's Avatar
Re: Raised tilt bed floor info/pics/suggestions
I would make a frame for the bed wood to sit on using square tubing then weld tabs for the frame to rest on at whatever height I wanted the bed to be at. Not sure how I would hinge the bed either, but maybe look for two or three quality hinges possibly designed for this already and mount to the frame supporting the bed wood and the front bed panel. Not sure how I would reinforce the front bed panel, or if that's even a good idea, just throwing it out there.
For the rear wheel wells I would either have the frame supporting the bed wood sit on top of the flange at the bottom so it can raise up and leave the tubs bolted to the bedsides OR possibly just mount the tubs to the bed so they raise together.
Just throwing ideas out there. I would have to play around with it quite a bit first before I committed to anything. Since you posted this have you came up with any ideas?
dougf is offline   Reply With Quote
Old 09-27-2015, 09:46 AM   #3
groundbound64
Re: Raised tilt bed floor 64 stepside info/pics/suggestions
I built a frame for the wood to sit on.( here's a pic of it. ) I also built a bracket at the tailgate so frame can rest on it. I'd like to have it hinged at or near front of the box.
Old 09-27-2015, 05:49 PM   #4
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hi groundbound64... Nice Stepper!
Lower50s was building a tilting floor... have a look at his build thread starting with post #288. http://67-72chevytrucks.com/vboard/s...648459&page=12
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 09-27-2015, 06:17 PM   #5
joedoh
joedoh's Avatar
there is a guy from oklahoma with a gorgeous black 60-66 that hinged his bed floor.
coulter is his screen name
http://67-72chevytrucks.com/vboard/s...449548&page=35
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
