09-26-2015, 12:48 PM | #1 |
Clearance for 22's
I have a Porterbuilt stage 2 front and rear kit with 2.5 drop spindles and bags. The control arms are 1" forward. I also notched the rear but keeping the bed floor and wheel wells original.
Is it possible to run 22" wheels without hitting the factory inner fenders or suspension? Thanks |
09-26-2015, 05:16 PM | #2 |
Re: Clearance for 22's
Wheel diameter doesn't matter. It's the tire size and wheel offset that are the important variables.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
09-27-2015, 03:26 AM | #3 |
A guy with a truck
Unless running a VERY short tire, you will hit tire/fender when aired-out. Options are to install bump-stops that limit travel, or modified/aftermarket inner fenders.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
