Old 09-27-2015, 02:01 PM   #1
MidWest72C10
One Piece Window, Flush fit back glass
Anyone installed one of these?
http://www.onepieceproducts.com/Prod...%20GLASS%20KIT
Scott
Daily Driver:2010 Z71 Ext Cab
Project:1972 C10 SWB
MidWest72C10 is offline   Reply With Quote
Old 09-27-2015, 04:47 PM   #2
JDL
JDL's Avatar
Re: One Piece Window, Flush fit back glass
Looks good
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 09-27-2015, 04:55 PM   #3
Eddie H.
Eddie H.'s Avatar
I installed one of their 1 piece window kits in a 71 GMC. I will never do that again, and I wouldn't recommend it to anybody else either.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-27-2015, 05:55 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: One Piece Window, Flush fit back glass
Can you give us some reason's why please?
Got any pictures of it installed?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-27-2015, 06:58 PM   #5
Eddie H.
Eddie H.'s Avatar
There are a lot of problems with it. To start with, the glass really won't fit in the door without quite a bit of modification. You have to cut out the brace behind where the wing vent goes. You have to remove the latch assembly and grind it down for clearance, then you have to grind out a section inside the front of the door for clearance. The glass guide doesn't offer much support for the window and it flops around loose unless it is all the way up or down. When everything is installed and aligned, there is still a gap at the front of the glass. The gap is mostly covered up by the lower weatherstrips, but it still has a lot of wind noise at highway speeds. It looks pretty nice installed, but I would never do it again.
Old 09-27-2015, 07:33 PM   #6
JDL
JDL's Avatar
this story is about the back glass
72 nova project car
Agency Iowa
Old 09-27-2015, 07:42 PM   #7
Eddie H.
Eddie H.'s Avatar
Yep, I realize that, however, based on the experience I had with their one piece window kits, I wouldn't want their back glass kit either.
Old 09-27-2015, 09:04 PM   #8
Andy4639
Old member
Andy4639's Avatar
Red face Re: One Piece Window, Flush fit back glass
I guess I'm to blame for his post. Sorry I wasn't thinking about it being the side window he was speaking of either in his first post. I thought it was the back glass also.
Old 09-28-2015, 06:15 PM   #9
Eddie H.
Eddie H.'s Avatar
No harm done, I didn't intend to get so far off track either.
