Help Needed- Engine Cutout
While driving my 66 today the engine would cutout at 2500 rpm when in third gear. I was able to bring it past 2500 rpms in 2nd and 4th, but for some reason every time I would reach 2500 rpms in 3rd it would cutout. If i let off the gas it would come back on and chrip the tires a little. If I kept the accelerator down and try and pull through it the engine would completely die and I would have to restart the truck. It runs fine as along as I don't reach 2500 rpms in 3rd. Any ideas as to what is causing this?
Truck Info: 1966 C10 307 engine out of a '68 Muncie 465 transmission Electronic Ignition Thanks, Chance
1966 Chevy C10 SWB |
![]() Join Date: Jan 2011
Re: Help Needed- Engine Cutout
Sounds like it is running the carb dry. Fuel filter or pump would be where I would look first. What carb is on it?
JImmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
It has an Eddlebrock 1405 carb. Any advice on how to diagnosis the carb and pump? Any advice is appreciated as I'm still a rookie.
Thanks, Chance
Post Whore
![]() Join Date: Mar 2013
If you were to pull the choke in 3rd would it help keep it going? Sounds like its running lean at that particular time for some reason. Might be that the fuel pump is going out or you have a clogged filter.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
The choke is not hooked up. I will have to check the filter and see if it's clogged. I believe that it has a new fuel pump, but I can't be 100% for sure. It just seemed odd that it only does it when in 3rd gear. I can run it at 2500 rpms or higher in any other gear with out it cutting out. It does not backfire or sputter as well.
Thanks, Chance
Post Whore
Could be the ignition to....What's your initial timing set at? My old 292 would cut out Once in awhile at 4200 RPM...and I mean ONCE in awhile...And I think it was either valves or ignition. In 3rd gear the engine needs the most fuel as that's really the Main acceleration gear.
Just throwing this out there in case it turns out to be the fuel pump. Edelbrock carbs don't like more than 5.5 lbs. of fuel pressure so keep that in mind if you need to get a new one. You might also check the FP of your current pump.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
I noticed that you don't have a fiber or phenolic spacer under your carb. When I had the Eddy on mine, it would boil the fuel and create a bunch of weird symptoms kind of like you're describing. Once I put in a 1" spacer, it ran fine although I would agree with previous answers about it sounding like it was getting run dry too.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
+1 on the carb spacer.
as far as my carb tuning went. absolute must do's - spacer -check fuel pressure -check float height i would spend a day though to go thru your timing, advance curve, clean the carb if it hasn't been cleaned, and definitely get a tuning kit with different metering rods, springs, and jets. it sounds like a lot of work, but its worth it. get a buddy, take your time, and only adjust ONE thing at a time. its really not that bad. and you will learn a lot about your motor. but i would go richer a main jet and try switching your ported vacuum to manifold, and then re-do your timing curve.it might suit your truck better. thats what really helped mine. Last edited by scum1; 09-28-2015 at 01:25 AM. |
