(2) pulse/delay wiper kits (complete, OEM!)
I believe one is for 1977 only, the other is 78-83 but please correct me if I'm mistaken-the available info on these are varied. Either can be added to any truck with standard wipers as far as I can tell wiring/wise. Easy to add....replace leads @ fuseblock, add the ground and splice in the grey dimmer wire to any existing grey dimmer and you're done. These are plug n play other than adding the grey splice.
Asking $125 shipped for either one. 78-83 shows "washer/wiper", the 1977 does not. |
![]() Join Date: Jun 2009
Re: (2) pulse/delay wiper kits (complete, OEM!)
Neither of those are actually for 1977 models. The 77 only ones that I have are black plastic faced and say Washer Wiper. The module also mounts with 2 screws to the pedal assembly where the relay for power windows bolts.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Ah...OK. The one which has "wash/wipe" is from a 6/78 build date Silverado. I believe the other one is from a 1975 GMC which I parted out awhile ago.
1977 was actually the first year for these. It seems like all of the 78-83 interchange though
the controller stamped with part #14056557 fits 78-82 C&K trucks and will also fit 78-81 g vans. the controller stamped 459485 doesn't come up in my gm truck parts book.maybe from carline that someone wired to fit in the 75 ? Bob
