Old 09-12-2003, 03:35 PM   #1
beeroh
Bought some steel braided brake lines ..
any suggestions to what I should do first
Any precautions that i should know about before I jump into it
84 Silverado,
beeroh is offline   Reply With Quote
Old 09-12-2003, 03:49 PM   #2
Low83
Talking
Flush all the OLD brake fluid out first,
Low83 is offline   Reply With Quote
Old 09-12-2003, 03:50 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Depending on where you got them from, make sure the actually work.
As for replacing them, just start unbolting them one at a time and replace them. Plan on bleeding the brakes IMMEDIATELY before driving.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-12-2003, 03:51 PM   #4
beeroh
all the bolts that hold the brake lines in are caked with crap, is there any kind of crap remover that would help loosen all the crap that built up on the brakes over time?
84 Silverado,
Old 09-12-2003, 03:54 PM   #5
Captkaos
Captkaos's Avatar
Being a 4x4, I would probably take it to a pressure washer and go to town. Especially if there is alot of crap on it. And if it is that bad, think about replacing some u-joints and seals.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-13-2003, 12:01 AM   #6
hrc200x
I also want to get braided brake lines.
WHere did you get yours?
Which lines did you get? The two front rubber ones plus the one rubber one in back?
How much was it?
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 09-13-2003, 01:32 AM   #7
beeroh
I got the brake lines from
4wheelparts.com
It cost me 107 to my door.
It aint cheap, but I'd rather be safe then sorry.
84 Silverado,
