09-12-2003, 03:37 PM | #1 |
combination switch on steering column doesn't work
can the combo switch be swapped with another or do I have to buy an entire new steering column with the switch
84 Silverado, |
09-12-2003, 05:09 PM | #2 |
I'm back with 2nd truck!
combintation switch? This is new to me
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
09-12-2003, 06:48 PM | #3 |
Professional Grade
If you need a new combination switch, it is a fairly simple matter to get at it, you'll need a steering wheel puller, a locking plate compressor, and a phillips screwdriver. You can build a locking plate compressor / wheel pulled using a remotely thick peice of steel with three holes drilled at the right distance apart, make sure the middle one is big enough to get the steering column top through it so you can bolt it onto the shaft, then drive two screws down into the wheel, or down onto the locking plate
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-12-2003, 09:48 PM | #4 | |
Me too ??? |
09-12-2003, 10:32 PM | #5 |
The combination switch that came with the truck is a turn signal with..
cruise control high beam switch intermitent wiper pretty much the same kind of switch that you find in the camaro's 82-92
84 Silverado, Last edited by beeroh; 09-13-2003 at 01:38 AM. |
