how much play should be in the rear driveline?
crawled under my truck yesterday and I was playing with the drive shaft with the tranny in N. I have about 3/4 of play when I turn the drive shaft from the rear axle to the back of the transfer case. Is this bad?
when ever I go in to reverse or Drive you can hear the CLUNK. sounds like crap, how do I attend to this?
84 Silverado, |
It's time for NEW U-Joints,
I was thinking it might be the u joints but they have no play at all...
the guy who is selling the truck told me that the posi is the reason for the play, can this be so? the play seems to start at the transfer case and continues to the diff. what is giving more?
84 Silverado, |
It's due to "slack" in the rear end itself. I had this problem in mine. Changed to an Eaton posi and now it does not do it. I think this is a common thing among older Chevy trucks.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
ummm, the Eaton posi on mine was installed a year ago, and I guess its doing it worse now than before, how do I adjust for the slack?
84 Silverado, |
Do you like working on differentials? I hope so, cuz if the differential is the problem you're going to be shimming and adjusting enough to make you want to sell the truck! If it is in the differential, it's because the ring gear is too far away from the pinion. Get the shim pack out!!!
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive! |
How much do you think it would cost for someone to adjust my diffrential?
84 Silverado, |
Right turn Clyde
Mucho denairo
Find some specs on backlash, and get yourself a dial gauge. Check the backlash by moving the pinion. If it's out of spec, it's the ring gear. First of all open up the rear cover and look for obvious damage and play. Maybe it's a bearing...
My advice is become one with the clunk. Mine has been doing it for years!
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
#11 | |
from park to reverse it goes CLUNK
from Reverse to Drive it goes CLUNK and vise versa
84 Silverado, |
