Old 09-12-2003, 03:55 PM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
What year axles are interchangable?
1. I am in need of a front disk 8 lug front end. (rear is already 3/4 ton) What years can I get this off of?
2. What are the highest (numercally) gears available in stock form? I priced around some shops and I was quoted $2K to change the front and rear to 4:56 from 3:73!! Holy crap!! I would like to find the right gears in the axle i buy and only have to change the rear gears if possible. (Dream on right).
Thanks.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-12-2003, 11:56 PM   #2
leadfoot067
horsepower junkie
you can use any 73-88 truck or 73 to 91 suburban front end...if you wanna dana 44 then they ran from 73 to 77ish or so...then gm switched to 10 bolts...either will bolt in just fine...
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 09-14-2003, 12:01 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The only difference will be the brake line banjo fitting changed from standard to metric in the late 70s. Should be able to find 4.10s, harder to find 4.56s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
