Old 09-12-2003, 04:01 PM   #1
dubie
dubie's Avatar
flex fan VS clutch fan
I have one of each now. What would be the best to run on my 350?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-12-2003, 04:13 PM   #2
68 Suburban
68 Suburban's Avatar
clutch....flex fans are garbage, and they are dangerous.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 09-12-2003, 04:31 PM   #3
nate68
electric fans
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-12-2003, 04:44 PM   #4
crazy longhorn
Fabricate till you "puke"
2nd the electric fans! I have 2 -14" flexalites on a hand built shroud......there is power to the rear wheels that you can feel after removing the eng driven fan I never did like the clutch fans, felt they were too inconsistant. flex fans are down right "spooky" (dangerous), but they work well for keeping a hp eng cool. I have run a flexalite PLASTIC flex fan with good results. It kept my 461 Olds cool in traffic on those 100 degree days....also worked well on my 383. The fan was also cheap, about $10 or 12 through summit racing. That thing did eat a little power to run, but thats better than a smoked engine. if you run a flex, be carefull! Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-12-2003, 04:50 PM   #5
junkyardjohn
junkyardjohn's Avatar
DUBIE .. GO WITH THE CLUTCH FAN. ELECTRIC FANS ARE OK FOR AN AUHSILLARY(SP) FAN , BUT DON'T MOVE ANYWHERES NEAR THE AIR A CLUTCH FAN DOES (CHECK THE CFMs YOURSELF) & FLEX FANS ARE JUST PLAIN DANGEROUS JUNK. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-12-2003, 04:57 PM   #6
dubie
dubie's Avatar
I have the clutch fan already installed on the engine, but my neighbour gave me a 7 blade flex fan last night so I figured I would ask the experts.
Thanks guys
Old 09-12-2003, 05:11 PM   #7
crazy longhorn
The fans I have on the longhorn dont even need to run if the truck is moving(plenty of air flow through the rad). The 383 holds between 185-190 on temp on the hottest days in Illinois, in town or on the hyway! If I start bangin all 6 of those gears.....the fans need to be switched on before I "play"! John, do you have a link to cfm ratings on the eng driven fans? crazyL
Old 09-12-2003, 05:19 PM   #8
tom hand
CCRider
tom hand's Avatar
I'm sure you rarely need a fan
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-12-2003, 05:22 PM   #9
COBALT
COBALT's Avatar
What's involved with installing an electric fan(s)? I'm curious. I've been toying with the idea of dumping the fan, shroud and clutch and simply using an electric fan setup so I can cap that pulley on the water pump.
Do you wire it to ignition? How is it grounded? How does it mount? Are there any required modifications?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-12-2003, 05:40 PM   #10
crazy longhorn
Check out the dual fan setup Wes has on his site.. http://www.classicheartbeat.com/cata...assemblies.htm
Old 09-12-2003, 05:44 PM   #11
crazy longhorn
The temp guage doesnt lie......as long as the truck is MOVING (was the key word), the fans dont need to run much at all. i havent burned up the eng , so it must work crazyL
Old 09-12-2003, 08:22 PM   #12
junkyardjohn
SORRY CRAZY LONGHORN ... I DON'T HAVE A LINK.... HERES AN EXCERPT FROM SEPT. 2002 CHEVY DUTY. I'M SURE YOU ALREADY KNOW THIS INFO, BUT MAYBE IT'LL HELP SOMEONE ELSE.
HERE GOES.....
THE BEST ALTERNATIVE TO A MECHANICAL FAN IS A DUAL ELECTRIC FAN THAT CAN PULL ALMOST AS MUCH AIR AS A MECH. FAN, REGARDLESS OF ENGINE SPEED, & THEY CAN SAVE SOME HORSEPOWER TOO. THEY COOL BETTER IN SITUATIONS LIKE STOP & GO STREET TRAFFIC. ALWAYS MOUNT THEM ON THE BACK OF THE RADIATOR TO PULL AIR THRU FOR THE BEST EFFICIENCY.
AND FEB. 2002 CUSTOM & CLASSIC TRUCKS
IT'S NO SECRET THAT ELECTRIC FANS ARE PRETTY MUCH THE NORM OF THE DAY. BUT THERES A CATCH WHEN IT COMES TO FANS:YOU HAVE TO GET SOMETHING WITH SUFFICIANT POWER TO COOL THE CAR, BUT AT THE SAME TIME GET ONE THAT DOESN'T HAVE A RIDICULOUSLY HIGH AMPERAGE DRAW. BUT REMEMBER, IN A TRUCK WITH A SMALL-OUTPUT (STOCK) CHARGING SYSTEM, THE PERFORMANCE DIMINSHES AS THE ENGINE SPEED DECREASES. SLOW SPEEDS = LOW AIRFLOW THRU THE RADIATOR & CAN RESULT IN OVER HEATING. SO DON'T SKIMP WHEN IT COMES TO ALTERNATOR AMPERAGE.
ALSO.. NOT ALL FANS ARE CREATED EQUAL.... YOU NEED A FAN THAT MOVES AT LEAST 2400 CFMs OF AIR. WHEN SEARCHING FOR ELECTRIC FANS, I THINK YOU'LL FIND THAT MOST OF THEM DON'T. HOPE THIS HELPS JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 09-12-2003, 08:37 PM   #13
crazy longhorn
Thanks john, I do agree that most of the elect fans dont pull the cfm that the crank driven fan did from what I see on "sales pitch", a 400 hp sb should be running 4000-4500 cfm on elect fans. Mine runs 2700-2800 cfm, & does great cruising.....runs a little more idling in traffic, & flat runs on wide open throttle! The way it was explained to me was that most of the driving that you do wont be pulling max power (or making most heat).....the 1st 4 gears in that longhorn will run that temp from 180 to 200 degrees d@mn fast if the fans arent running! Its not the same , I do agree! I think that climate has a lot to do with the mix, as we say HOT in Illinois, & we are talking 100 degrees.......nothing like you see out your way ,Ill bet crazyL
Old 09-12-2003, 09:54 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Dubie, i would personally toss that flex fan in the trash. I have seen them explode and rip right through the hood. Sliced through i like it was paper.
It is not n isolated incident, there are stories of it happening in every aumotive group you see, and I have seen the remains of 3 other flex fan explosions. (however, I did not see them blow up with my own eyes)
Old 09-13-2003, 12:34 AM   #15
Injected68LS1
Injected68LS1's Avatar
My flex fan exploded! That ruined my perfect exterior. It wasn't the fans fault though because my water pump shaft broke off at full throttle. It cause 2K of damage.
GET an electric fan. But get a good one. I have a 16", curved blade fan by SPAL. It flows plenty and I don't even have a fan shroud. It is just on the back of my radiator and tranny cooler. Another plus is that you never have to lean over a fan blade to adjust your engine.
I live in Southern California and I have never overheated with this fan.
enjoy
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 09-13-2003, 10:08 AM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Clutch fan or the plastic flex a lite fan work's great too..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-13-2003, 02:46 PM   #17
slam33
slam33's Avatar
My 2 cents worth, I've been running flex fans for a lot of yrs and have never had one go on me. I have a flex in my driver and it's been there for 5 yrs now. Clutch fans put a lot of weight on the water pump bearing, for me I don't like that. Electric fans worry me as to there reliability. Is it going to quit on me while I'm stuck on the 405 in the middle of the day ? For me the less moving parts something has, the better.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-13-2003, 03:42 PM   #18
junkyardjohn
THE OLD RULE "THE LESS MOVING PARTS THE BETTER" DOESN'T ALWAYS APPLY TO FANS. LOL
junkyardjohn
DON'T RENT U-HAUL
Old 09-13-2003, 05:08 PM   #19
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The last flex fan I had, had to be hammered out of my hood! Right through the hood and the reinforcement under it like a hot knife through butter. NEVER AGAIN!
Mine was the stainless steel type and from the flexing, one blade broke off. (not the rivets)
My truck now wears a good old steel 4 blade, no frills fan. It doesn't overheat, so that's good enough for me.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-13-2003, 07:35 PM   #20
racedvl
racedvl's Avatar
Ditto!!!
racedvl is offline   Reply With Quote
Old 09-13-2003, 09:59 PM   #21
casey
casey's Avatar
all i have to do is imagine that fan coming apart when your playing under the hood, I find those clutch fans don't last, my truck kept over heating with the clutch fan so I put a stock 5 blade on problem solved, as far as power loss goes you might only care if your always racing
casey is offline   Reply With Quote
Old 09-13-2003, 10:38 PM   #22
nate68
a higher output at idle alternator is a definate must when dealing with electric fans. i killed a powermaster one in about a year's time and i dont drive that many miles in a year. i bought another powermaster but one that puts out 70 amps at idle, peaks at 2000 rpm. $125 for polished aluminum one from summit. well worth the money and no more jumpy tach.
Old 09-13-2003, 11:00 PM   #23
rickspickuppart
flex and electric are always a problem in hot areas, if the oem thought they were a better idea they would have used it, ours is a 542 cid motor w/ a mech fan and a severe duty clutch on a reverse rotation serpintine w/ a full and it never gets 1/4 of the way up the gauge (with a/c on in arizona)
rickspickuppart is offline   Reply With Quote
Old 09-16-2003, 01:06 AM   #24
GMC Jim
GMC Jim's Avatar
Have had several vehicles with clutch fans ( over the past 25 years!).....Never any problem; but possibly the weight of the clutch fan might shorten the life of the water pump bearing...( I have replaced water pumps.....
Using a clutch fan with my 402 engine with a marginal 3 core radiator and air conditioning.. On rare occasions; 100 degrees and slow traffic... pegged the temp indicator needle....to remedy just shut off the air conditioning, blower to high speed and heater on.. Rev up the engine some; temp comes to normal in less than a minute!.........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 09-16-2003, 01:34 AM   #25
Mechanic
Ok,
I'll check in on the fan issue. My experience with Flex-a-Lite electric fans has been with class D, 84 passenger school buses. We repowered 8 buses with Cat 3208 turbocharged 250hp engines back in 1992. When we took the cummins 555's out, the cummins hydraulic fan drives went with them. We left the same radiators in place and installed 4 Flex-a-Lite fans (2 outside, 2 inside) and the controllers with each power unit.
The only problem we have experienced has been some of the relays in the contollers failing. They were Bosch-type 40 amp relays and about 30% of them failed. After the first 2 or 3 failed we replaced them with HD Cole Herse continuous duty relays. As far as the fans themselves, they really move some air!
My suggestion for anyone trying to cool using these fans would be to use a dual-circuit Kysor brand switch to control on and off, and a Cole Herse relay to handle the amp load.
Shop Labor $75, if you watch $100, if you help $125, Wisecracks-$25,
Boxjobs-don't even think about it. Yes,Cash.
Mechanic is offline   Reply With Quote
