Vss
I have a aftermarket harness for my 5.3 700r4 swap in my 63 gmc that has a two wire connector for VSS. do I need to have a VSS hooked up to run the 700r4? if so where does the sensor go? thanks.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: Vss
It can help with the lock up converter control, but other than that, a 700R4 is mechanical.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Re: Vss
Yes I'm aware of that...I guess what I'm asking is. .... does the pcm need to have a vss signal in order for the motor to function properly? Right now I can't get WOT it's acting like it's starving for fuel....
