Old 09-28-2015, 09:33 PM   #1
dzbowtie
dzbowtie's Avatar
Bad brake squeal at slow stop
Hey guys, I've got an all drum 70 and have recently been fighting a bad squeal at a slow rolling stop, such as a stop sign. If I get on the brakes with a good amount of pressure, there is no squeal. This is high pitched. The shoes are new. The squeal seems only to be coming from the front driver side. Thinking they may have glossed over, I buffed them with some 60 grit and blew out the hardware. The drums are not perfect, can feel slight grooves in them. Is turning, or new drums, the answer? Any suggestions would be greatly appreciated!
dzbowtie is offline   Reply With Quote
Old 09-29-2015, 07:02 AM   #2
PGSigns
PGSigns's Avatar
Re: Bad brake squeal at slow stop
May have a drum getting thin. Do you have a way to measure them to see if they have been turned past the max diameter?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-29-2015, 09:55 PM   #3
travlinman
I have this same problem on my 97 ext cab. Pass rear brake. Replaced shoes and drums and still there. Very annoying! I've taken it apart several times and always have more brake dust on that side. I clean it and it stops for 20 mins and comes right back. I don't know what's causing it. And I don't want to keep buying parts and having the same problem.
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 09-30-2015, 05:29 PM   #4
dzbowtie
dzbowtie's Avatar
I pulled the drum and had it turned. It had plenty of meat left and turned very nice. The bad squeal is gone. Hopefully it stays that way!
