09-29-2015, 12:46 PM | #1 |
Mild cam?
09-29-2015, 01:20 PM | #2 |
Re: Mild cam?
If you mean mild like in stock, then yes!
09-29-2015, 09:09 PM | #3 |
Re: Mild cam?
Sounds like stock are just a tad over. Maybe an RV type cam which is usually around 204º at .050 intake duration.
09-29-2015, 09:48 PM | #4 |
Re: Mild cam?
My 74 k5 this is what I would consider a mild cam Comp xe256
http://youtu.be/vvNodZncky8
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-29-2015, 09:51 PM | #5 |
Re: Mild cam?
Says private video
09-29-2015, 11:00 PM | #6 |
Re: Mild cam?
It sounds stock to me, but some of the very mild cams do sound stock, so its hard to say. It doesn't sound anything like my truck. https://www.youtube.com/watch?v=LprC_LPKj1c
Matt
1984 C10 long bed. Built 383, Lunati VooDoo flat tappet 233/241*(.050) 504/525 lift, Brodix IK200 heads, Edelbrock RPM air gap, Holley 750 DP. 700R4 Trans, with shift kit, and 3000 stall. 3.42 gears. 1993 K2500 ext/LB, 4x4. 3.42's, 4L80E, 6.5 TD, Holset Turbo, Intercooled, modified IP, 4" exhaust |
09-29-2015, 11:21 PM | #7 |
Re: Mild cam?
09-29-2015, 11:25 PM | #8 | |
Re: Mild cam?
09-29-2015, 11:31 PM | #9 |
Re: Mild cam?
My link should work now
10-05-2015, 07:44 PM | #10 |
Re: Mild cam?
I too have the comp he 260 in my 454 and you can actually tell it has an aftermarket cam in it! I figured the idle would be dead smooth
"DON'T TOUCH THE TRIM!!"-Early Kyler |
10-05-2015, 08:08 PM | #11 | |
Re: Mild cam?
its a bit lopey in park and pretty nice sounding at 550rpms |
10-05-2015, 08:28 PM | #12 |
Re: Mild cam?
They might mean through stock manifolds, mine has headers, I'm sure yours does too, I have a video of mine but it's not on youtube, so I don't know how to post it here
10-05-2015, 11:43 PM | #13 |
Re: Mild cam?
10-06-2015, 11:47 PM | #14 |
Re: Mild cam?
