09-29-2015, 04:27 PM | #1 |
Battery Relocation
Need to get the battery off the passenger side. Driver side would be OK. So would really any other place other than exposed in the bed or something race only. Where have you moved it?
09-29-2015, 04:34 PM | #2 |
Re: Battery Relocation
Driver's side frame rail
09-29-2015, 04:53 PM | #3 |
I put mine under the bed on the passenger side and put a cut off switch along the line so I can kill battery power. Just a small safety device. If I were to do it over I would put it on the driver side, only because when I park in the garage the passenger side is against the wall. Makes it hard to get to if it dies. I also took out the indent on the inner fender where the battery box sits.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-29-2015, 04:56 PM | #4 | |
Enjoy your truck
I put mine on the passenger side frame rail as well. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
09-29-2015, 09:39 PM | #5 |
I liked this one. In cab and in unused space.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-02-2016, 09:02 PM | #6 |
05-02-2016, 09:19 PM | #7 |
Looks just like the one on my 56 came from No Limit . stainless steel drops down by removing bolt at bottom. hope this helps lumpy
05-03-2016, 12:13 AM | #8 |
meowMEOWmeowMEOW
05-03-2016, 11:26 AM | #9 |
No Limit Engineering. It has no built-in lowering mechanism like others on the market and is a PITA with a battery installed and overpriced for what it is. I'd look elsewhere for a better one.
05-03-2016, 02:06 PM | #10 |
If you go do a Google search...there are several options for battery boxes. Side mount, weld in place, drop down box, bolt on, etc. $35 to about $100 on Speedway and the reviews looked really good for the most part...$24.99 on Summit
Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 Last edited by par4tom; 05-03-2016 at 02:17 PM. |
05-03-2016, 09:00 PM | #11 |
It's Better With Nitro
I moved mine to passenger side rear of the frame. Fabricated a mount to slide the batter box up onto...
