Old 09-29-2015, 04:34 PM   #1
jb9281
jb9281's Avatar
high temps under the hood.
My engine bay gets very hot. I am running a 350 4 barrel with rams horn exhaust manifolds. How hot should it get under the hood when idleing? The manifolds get about 460-475 degrees with my infared gun. Would it run cooler with headers? I only have about 150 miles on this truck since resto.
jb9281 is offline   Reply With Quote
Old 09-29-2015, 05:13 PM   #2
craiginaustin
craiginaustin's Avatar
Re: high temps under the hood.
I don't know about manifold temp, but my temp gauge reads 180-200 F (at most).
It was running much hotter until I realized the timing was too far advanced. Running lean = higher temperatures.
craiginaustin is offline   Reply With Quote
Old 09-29-2015, 05:42 PM   #3
ProudSoul
ProudSoul's Avatar
I dont know about manifold temp either. My gauge goes to 200 if its idling forever. I switched from longtubes to ramhorns and noticed a huge temp difference (around 30 degrees). I had to switch to distilled water and water wetter to keep it under 200. Those ramhorns build up heat like no other! I had problems with vapor lock too after the switch and had to move my fuel line around
ProudSoul is offline   Reply With Quote
Old 09-29-2015, 05:57 PM   #4
craiginaustin
Oh, forgot to mention I'm running the stock cast-iron manifolds.
Old 09-29-2015, 07:08 PM   #5
jb9281
jb9281's Avatar
My factory heat gauge runs from half way {driving down the road} to 3/4 {when idling with ac on -15 mins} Infared gun reads reads about 185-200 on t-stat housing at 3/4 gauge. no water boiling over, does not appear to be running to hot. Just seems like a lot of heat under the hood when idlining. Running a champion 3 row with a 17" 2400 cfm puller fan with a flat aluminum shroud.
Old 09-29-2015, 07:23 PM   #6
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
To much Timming and Not enough Fuel Causes Lean Burn and high Temperature
Check your Carb and Fuel Pressure
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 09-29-2015, 08:00 PM   #7
jb9281
jb9281's Avatar
new manual fuel pump, new elderbrock carb, have not checked the pressure. How can I check pressure without adding gauge?
Old 09-30-2015, 12:50 PM   #8
61K10
61K10's Avatar
Just a note--remember that everything under the hood is metal (not plastic as in today's stuff) gonna be warm under there.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-30-2015, 02:02 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Headers are thinner and will make things run hotter. If your running 200 degrees at idle that's no big deal. Its when you get to the 215-220 rang you want to be careful. Might try seeing what your initial timing is set at. Maybe turn your a/f screws out 1/2 a turn and see if that helps.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
