Old 09-12-2003, 06:12 PM   #1
bigd65
bigd65's Avatar
fans (electric)
well i took off my fans today and put back the clutch fan. while i ws messin around with the distributor, i had another whole distributor in peices, so i put a stock one together. well i put it on, ALL STOCK COMPONENTS, so i can see if i can get the 12* initial timing. well i noticed that the engine felt HOT, but the gauge showed under 180*. i was listening to this guy the other day and he had soomething about he tried the whole electric fan deal and couldnt stop it from running hot. well i figured i would check it out and put the clutch fan back on with the shroud. well i can tell one thing, it sure moves ALOT more air than the electric fan.
as far as the timing, i dont know yet, i'll let yall know. BTW, i think my temp gauge is bad. anyway if it was running hot, it never boiled over. WE WILL SEE.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-12-2003, 07:06 PM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
Question
Wonder if the guy had a pusher fan and mounted it on the wrong side of the radiator where a puller fan is suppose to be?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 09-12-2003, 07:30 PM   #3
Russell
Professional Grade
Russell's Avatar
If you want a new electrical temperature guage, I have one here I can give to you.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-12-2003, 10:14 PM   #4
bigd65
bigd65's Avatar
i appreciate it russell, but i am kinda thinkin about AUTOMETER> but they are really pricey. i kick myself in the @$$, the buddy of mine that owns the wrecking yard had one from a 91 burb. everything was exactly the same. i left it cause all my gauges work and i dont take things if i dont need them. i dont wana burn him up and he think i am using him. this guy is a really good friend. now i wish i would have. yep its gone
2017 Chevy Tahoe
