09-29-2015, 09:15 PM | #1 |
leveling my 62
hey guys, curious if there are tips and tricks towards leveling a 62 gmc flatbed? not sure if there are kits or just tighten the torsion bars as i have done on my dodge. i dont want to make the ride too much stiffer, and im not looking to lower it at all. any pics or links would be appreciated as well, thanks!
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L |
09-29-2015, 09:31 PM | #2 |
Re: leveling my 62
Find a "level" spot. Measure height. Find happy height, adjust to happy height. I cranked my Durango up and had no issues. Shocks help rebounds is light or if too stiff turn bars down. Once again a good shock not a cheap and too stiff shock will control bounce. And if needed check alignment after for a happier truck.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-29-2015, 09:51 PM | #3 |
Re: leveling my 62
Most "big trucks" were higher in he rear . You can adjust the t bars as mentioned.
Did you get the windshield in ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-04-2015, 11:06 PM | #4 |
Re: leveling my 62
sounds like ill be tightening the front torsion bars, hope they look similar to my dodge. im actually getting it put in this week, ill post a pic as soon as shes in!, thanks again sal!
