09-29-2015, 10:07 PM | #1 |
60-63 Idiot light to factory full Gauge conversion, what is all needed?
awhile back i traded for a really nice full gauge setup. and would like to put it in my truck. Whats is all required? im assuming there must be a sending unit for the temp gauge or something, and whatever wiring differences?
i thought i saw a thread awhile back that described all of this and for some reason after searching a few days and through the FAQ i cant find it. Any input is appreciated! Thanks in advance. Aaron
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
09-30-2015, 01:40 AM | #2 |
Re: 60-63 Idiot light to factory full Gauge conversion, what is all needed?
My truck has original warning lights gauges as well... Iv been planning to do the same. After doing my own research, all you really need to do is order the guage cluster under dash harness for "gauges" I believe which is at about somewhere around $50-$65. You can keep the same sending units that are the engine I believe.
09-30-2015, 02:16 AM | #3 |
TEMP sender will be different
09-30-2015, 08:50 AM | #4 | |
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
09-30-2015, 10:32 AM | #5 |
There are quite a few differences. The main harness (runs $200-300) and gauge harness ($50-75) are different. The sending units are different for the oil and temp also. Oil is plumbed from the block with no sending unit on the gauges. Temp sender is different and only 1 wire install as opposed to two wires for the warning lights. Fuel is the same wiring and the ammeter is wired different.
I'd recommend replacement harness's unless you are proficient and wiring and electrical. The clusters drop in the same as the warning light system.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-30-2015, 12:22 PM | #6 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
09-30-2015, 03:20 PM | #7 |
I am not changing the entire truck harness just because of the Gauges. I am not scared of Wiring I have wired many vehicles. Just curious what the differences are. Iknow ill need to get a sender for the Temp Gauge. oil pressure is a direct hookup. How is the Ammeter wired in these trucks? that's really the only challenge I guess. where does the power come from for the Temp Gauge on the Deluxe set?
I probably should have just been more specific.
