Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-30-2015, 09:16 AM   #1
morethanstock66
morethanstock66's Avatar
Mid-Best Single DIN Options
The PO cut my '66 dash to fit a single DIN. I can clean it up and fit in a good radio. The issue is I know little about car audio. I was curious if y'all could steer me in the direction of a good brand or away from bad ones. I'm not looking to blow the doors off of it, just something that looks fairly clean and will give me enough power to get decent sound when I hook some speakers, and possibly a small sub, to it. I would also prefer one with out spending $500 for just an indash. Thanks for the help.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 09-30-2015, 10:33 PM   #2
Kudzupatch
Kudzupatch's Avatar
Re: Mid-Best Single DIN Options
I have had good luck with JVC head units in two different trucks. There are a lot of options and other brands that I am sure are just as good. Don't remember my model number but it is just under $100 and I think it has 20 watt output? I replaced all the speakers and added a Sound Ordinance underseat Sub and stayed right in your price range. Very happy with my system!
If I have a complaint it would be the lower power doesn't allow me to turn it up as loud as I would like when I am working on the car or washing it with it closed up. But it way louder inside that I am going to ever listen too!
The sub doesn't rattle windows but I prefer a more realistic sound and would buy another in a heartbeat!
Kudzupatch is offline   Reply With Quote
Old 10-01-2015, 05:51 AM   #3
ranger danger
ranger danger's Avatar
Look at the Sony Explode series. Its not real expensive and is simple to operate. They have a bunch of stuff that's designed to go together. I find Kenwood to be the most complicated to operate.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 10-01-2015, 05:35 PM   #4
Kudzupatch
Kudzupatch's Avatar
May I suggest to spending some time at Crutchfeilds web site. I always assume they were high prices but a few years ago I discovered they are very competitive price wise. And there tech support turned out be good too when I had an issue.
You can read customer reviews on items before you buy.
Old 10-02-2015, 11:55 AM   #5
ratedrookie
Pioneer, Alpine, Kenwood, JVC, and Clarion will all serve you well. I'd personally stay away from any other head units.
If you are planning on adding an amp and subwoofer down the road, I'd look for something with a subwoofer output. Some models will have front/rear/sub and some will offer front/switchable rear/sub output. Having a subwoofer pre-out will allow you to have some control over your sub from your head unit.
Nowadays you can find a good single din in the $100 range, especially if you don't mind buying a model that is a year old.
ratedrookie is offline   Reply With Quote
Old 10-02-2015, 12:40 PM   #6
morethanstock66
Thanks guys. I've been doing lots of research and comparisons. It is kind of amazing how in depth some of these tuning capabilities are. It is strange looking through so much stuff I will most likely never use The wiring looks daunting to me due to the fact that each of these have 10-15 wires out the back. Is that really necessary? Power, ground, speakers, sub, antenna, aux, usb. I don't know what else they would go to..
Thanks for the tip Kudzpatch, I've been searching through there a lot lately.
Ranger, that is kind of what I am in the market for, semi-simplistic controls with enough oomph to where I can hear it over engine and road noise if needed, with clarity enough for nice playback at idle. Nothing too fancy.
Rookie, That is a good tip, thanks. I will try to keep in mind a sub pre-out for later down the road.
Old 10-02-2015, 01:27 PM   #7
_Ogre
_Ogre's Avatar
if you listen to the radio often go with a head unit with the cd/mp3 player
i'm all mp3 now and only use the usb port on my head unit, the rest is all dead weight
a mp3 player hookup with an amp(s) is really all you need
though it still leaves the single din hole in your dash
shop air compressor timer
Old 10-03-2015, 09:16 AM   #8
Kudzupatch
Kudzupatch's Avatar
_Ogre has a good point. I did store a lot of music on USB stick and playing it that way.
Now I listen almost exclusively to internet streamed music. Something 2 years ago I would have never expected. Now I regret not buying a head unit with Bluetooth.
Point being, out tastes change and something I never though I would use, I would now use every time I get in the truck.
Old 10-05-2015, 02:03 AM   #9
twistedchevy
Originally Posted by morethanstock66 View Post
Thanks guys. I've been doing lots of research and comparisons. It is kind of amazing how in depth some of these tuning capabilities are. It is strange looking through so much stuff I will most likely never use The wiring looks daunting to me due to the fact that each of these have 10-15 wires out the back. Is that really necessary? Power, ground, speakers, sub, antenna, aux, usb. I don't know what else they would go to.. .
Well 10-15 wires isn't much. The stereo will have 4 speakers witch each have a positive and negative wire, so their is 8wires then you have your constant hot to save settings your accessory hot to power it and your ground that's 3 more then you may have electric antenna. Which puts you at 12 wires
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
Old 10-06-2015, 01:18 AM   #10
king-918
king-918's Avatar
80-prs hands down one of the best with active crossover and auto time alignment
Amazon.com : Pioneer DEH-80PRS Mobile CD Receiver... Amazon.com : Pioneer DEH-80PRS Mobile CD Receiver...
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 10-06-2015, 09:18 AM   #11
slowcpe
slowcpe's Avatar
I've always been a fan of Kenwood and Alpine. I've probably owned close to 20 Kenwood head units over the last 20+ years. I've also had a few Alpines I liked. Back when I sold car audio, I installed a lot of Pioneers but personally never liked their sound. Still a very nice head unit though.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-06-2015, 08:26 PM   #12
OutlawDrifter
1 more vote for kenwood or alpine.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 10-14-2015, 11:43 AM   #13
morethanstock66
Thank y'all for all the help and advice. I am specifically looking at Alpine's CDE-HD149BT right now.
Old 10-15-2015, 08:40 AM   #14
biketopia
looks like a solid unit for sure, and plus one on the bluetooth. I have a high end pioneer in my 03 with GPS DVD etc...The bluetooth sounds so much better than using a 3.5mm aux. jack for streaming. Alpine and pioneer are my two choices. Do your research on crutch field and then check out a few other sites for what your looking for, I always tend to buy last years model also, find em on eBay, amazon, other third party sellers all day long for a great price.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
