Old 09-30-2015, 10:15 AM   #1
biohazardbill
Door Glass replacement
What is best way to get the old glass out of the channel to put in new glass?
biohazardbill is offline   Reply With Quote
Old 09-30-2015, 03:29 PM   #2
jb9281
jb9281's Avatar
Re: Door Glass replacement
You have to remove the wing window assembly first. Then the window slides toward the front off the truck and you lift up and out.
jb9281 is offline   Reply With Quote
Old 09-30-2015, 04:32 PM   #3
biohazardbill
Right, but i mean remove the actual glass from the metal channel at the bottom of the actual glass. Not remove the glass assembly from the door.
Old 09-30-2015, 05:11 PM   #4
jb9281
jb9281's Avatar
I laid my window glass flat on the workbench with the metal frame hanging off the workbench edge and slide the frame up to the edge and catch on the workbench edge. Then i took a wooden block and hammer and started tapping on one end of the glass until it broke loose and kept on tapping until it came out the frame. When i installed my new glass i just fill the frame up with black silicone , let it dry a few days and trimmed off the excess
Old 09-30-2015, 06:25 PM   #5
duallyjams
duallyjams's Avatar
mine pulled apart by hand
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
