09-30-2015, 11:00 AM | #1 |
Are my axle tubes coming out??
Guy im cleaning up the front Corp 10 bolt on my K10 and see this clean metal section that looks like its pulling out of the center section.. Thing is its like that on the other side as well.. not quite as clean metal looking but there is a same size ring that is smooth. Are they supposed to look like this, what do you guys think??
09-30-2015, 12:14 PM | #2 |
Re: Are my axle tubes coming out??
They kinda look like they moved. How are they lining up with your spring perches and do they look goofy?
The right side looks older than the left. Is there any small tack weld anywhere around each tube?
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
09-30-2015, 12:21 PM | #3 | |
I think ill go out and measure the peach spread and compare that to the hanger spread (front and back shackle). The shackle could move but the front is riveted to the frame and should have never moved. I don't see any welds. Would some pics form inside the tube help? Does anyone else's look like this? |
09-30-2015, 01:09 PM | #4 |
Do you have the diff cover off and carrier out? You could reach inside and see if it's pushed all the way in or out a bit. Those round things on the diff are the main plug welds that anchor the tube to the housing. I think that's the main holding part.
I don't know if the perches are the same distance in the back as they are in the front. The rear axle, by default from factory, is about 3" narrower than the front axle...so hard to compare very well. I could measure my front axle (and I just tried), but don't have a tape measure. I'll see when I get home tonight. But just glancing at it, mine does not show the shiny part as yours....
09-30-2015, 07:30 PM | #5 |
One of my dana44s and my 10bolt front are this way I believe it is were they machined the tubes to fit in the housing and they just went to far mine measure out normal just have that machined surface sticking out
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-30-2015, 07:46 PM | #6 |
My measurement is 14" from the edge of the differential side to the spring perch (on the driver's side).
10-01-2015, 01:35 PM | #7 |
I think you are right. I have looked at a ton of pics on Google and I keep seeing the same look.
10-01-2015, 01:36 PM | #8 |
I'm going to measure mine when I get to the house. Thanks for the measurement, we;ll see how it compares..
10-01-2015, 01:56 PM | #9 |
If you were able to remove the c-cip inside the carrier without banging the axle shaft in, I doubt it moved.
Edit: Sorry just realized this is a front with no C-clips |
10-02-2015, 08:18 AM | #10 |
There is no 'C' clip on a 10 bolt front axle. All the clips are at the end of the shaft in the hub.
10-02-2015, 08:54 AM | #11 |
These are the welds.
There were originally holes in these locations and the weld is "puddled" in the opening to attach the tubes. You can, if you like, run an addtional bead around the outside diameter of the tube at the center section. This is what I do for high performance applications. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-02-2015, 09:18 AM | #12 |
The spot in question looks just as rusty as the rest of it does.I think its just a mess up when they made it and it left the factory like that.
10-02-2015, 10:28 AM | #13 | |
Otherwise there would be too much variation at the joint as a result of the dimensional tolerance in producing the tube. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-02-2015 at 10:35 AM. |
10-03-2015, 03:55 AM | #14 |
I know how axles are made i have helped shorten a few over the years for jeeps.The point i was making his one tube was turned down to far is why you see the bare spot on it.
