Junior Member
![]() Join Date: Oct 2014
66 Fleetside Newbie
Hello All;
My name is Mike and am am located in the bizarre community of Venice California. I have a very clean (Arizona) 66 SB fleetside 283/4-speed.Looking to pull the motor for a rebuild and swap over to a automatic transmission 350/400 power steering and disc brakes. What issues or concerns may I encounter. I plan to leave the rest as is, kinda like the patina look. Thanks for your time. Mike |
Re: 66 Fleetside Newbie
Look like "the Grey Ghost" when I bought it....nice. leave the patina
Post Whore
![]() Join Date: Mar 2013
283 is a simple engine to rebuild so I wouldn't be concerned. Swapping to a 350/400 auto is a very common swap so finding someone to help out with that is easy as well. Nice looking truck. Diggin the patina.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Active Member
![]() Join Date: Aug 2015
Welcome.
Like the truck very much. Get your mechanicals updated but otherwise don't change a thing. |
![]() Join Date: Sep 2006
You might want to look into a 700R4 instead of the 350 or 400. I wouldn't put a 400 behind a 283. It robs a lot of horsepower.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() Join Date: Aug 2010
Hi Mike, and welcome. Sorry your first truck purchase needs an engine/trans rebuild right off the bat. I also see from the picture that it badly needs paint and has the wrong hubcaps.
It's obvious this is not a good start, but not to worry, I'm willing to help you out. I'll bail you out for a few grand so you can put that toward another truck with a good engine and shiny paint. I'm pretty close too. Deal? ![]() |
I was thinking the same thing. His rear gears are probably 373 or taller. Needs a OD tranny. I put a 200R4 in mine. Love it. Best upgrade yet, went from 10 without it to 15 mpg highway with my 350 GM HO 350 crate motor with HEI. A TH 400 would be a big mistake if your driving it.
#8 | |
![]() Join Date: May 2010
Welcome Ghetto Fireman great looking truck. I agree with the other's I would consider a 200R4 or a 700R4.
It only has original paint once |
![]() Join Date: Jan 2015
Welcome you come to the right place, Im in the middle of a 700r4,powersteering project, start collecting all your needed goodies belive me there are alot of things to get together!
60-66 Nut
![]() ![]() Join Date: Mar 2007
Welcome to the forum
![]() I agree with going with a 700R4, even though the 283's do like rpm's. You just need to be sure the TV cable is setup and adjusted correctly. If that is not an option, I would choose a TH350 over a 400.
