Truck newbie here. Need help w/EFI tanks
Hello fellas,
I'm all new to this truck thingy. I've built first gen camaros and now I'm building IROC camaros. Needed a truck and decided to get something "interesting". Got a 1965 Chevy C20. She's got a 350 out of a 1974 A body car and the rest is original drivetrain far as I can tell. I plan to transplant a 1989 350 TPI from an IROC. So that means a fuel injection gas tank. I've searched many threads about EFI swaps but nobody seems to talk much about the tanks. Who's got comments on which ones are best. Should I go with top filler tube or side. I'd really like side but I can't seem to find any pics of what that looks like. Thanks all |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Truck newbie here. Need help w/EFI tanks
Welcome to the forum
![]() Boyd Welding makes the best fuel tanks available. http://www.67-72chevytrucks.com/vboa...d.php?t=362307
Yes, welcome to the forum. I ran an 89 Blazer tank in my '63. Its a 31 gallon and it does hang pretty low especially for a 2wd. Im not sure if there was a smaller capacity Blazer tank that would not hang as low but Im sure that someone here would know this. The 89 tank sending unit is interchangeable with the 97 and I think that they both had different pressure pumps. You may be able to find a stock pump that will suit your LT1 that would also drop into your tank easily. Mine is a side fill although I have not cut in the fuel filler. Its given me a little anxiety thinking about cutting another hole in otherwise cherry fender.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
