09-30-2015, 12:22 PM | #1 |
Dana 60 Front for my 1965 K20? Width issues?
So I found a 3.73 front chevy 60. Problem is I think its wider than my stock 1965 GMC closed knuckle 44. Any insight on this issue? I believe my stock axle is 67.5" WMS to WMS and the 60 would be about 69.5 WMS to WMS? I don't want the front tracking wider than the rear...would it be better to go with a Dodge front 60? That should be 67.5 WMS to WMS?
09-30-2015, 12:37 PM | #2 |
Re: Dana 60 Front for my 1965 K20? Width issues?
I'm not sure about 65, but offroad design makes a kit to use a dodge dana 60 up front for my 69 k10 and though it's been pricey it is heavy duty. The dodge dana 60 has the spring perches a 1/4" on each side, so ORD (offroad design) has a bushing set to move springs to set perfect on the d60.
09-30-2015, 01:00 PM | #3 | |
09-30-2015, 02:32 PM | #4 |
All GMs have the front track width wider than the rear. I swapped 3/4 tons in my old 62' burb, fit and looked fine.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
09-30-2015, 02:33 PM | #5 |
Besides it's only an inch per side....
09-30-2015, 06:37 PM | #6 |
The front is wider than the rear on chevys. I have an '84 dana 60 in mine and it looks normal people don't even notice that it's been converted.
63 k20 with cummins 4bt, owned sence 1982 |
09-30-2015, 07:40 PM | #7 | |
Here's my nasty turd... but I'm simple to please... I guess.
White K20 |
09-30-2015, 09:03 PM | #8 |
Looks like a Dodge 60 is the way to go to keep it all same width. Sucks because I will have to regear a Dodge axle but I do want to keep the track narrow.
09-30-2015, 10:05 PM | #9 |
Yes a dodge 60 looks right for your truck. We may need the minority thinking that. Needs some skinny mud grips too.
09-30-2015, 10:07 PM | #10 |
Read my mind sir! Currently have 12.5 wide and 35" tall muds. Planning to replace them with 35 tall and skinny as possible michelin muds as soon as I can.
09-30-2015, 10:52 PM | #11 |
Cool thing about a dodge 60 is that it has 1/2" studs to match the rear. A chevy 60 is 9/16. I'm building a 65" kingpin dana 44 and a 63" eaton rear. I am a big fan of narrow axles and tall skinny tires.
09-30-2015, 11:13 PM | #12 |
I'd love to build a front 60 using the Dodge tubes and the 79 Ford high pinion center section...wouldn't really be that difficult...
09-30-2015, 11:18 PM | #13 |
Nah. Where it's at is the 05 and up super duty axles. Cut the tubes put of the inner c. Retube it and use the super heavy duty outers on these new f250s. Use the leaf sprung high pinion diff from an 04 and older f250 axle. As of right now they are going for 125 an axle in the yards. They're everywhere. Very reasonable for the axle builder.
But a dodge 60 bolts in. |
10-01-2015, 12:01 PM | #14 |
Any how. After you swap in the dodge 60 put some spacers in your rear so you have the same wms width front and rear. That is what you are after... and not what you have now!
But in all fairness, I should disclaim I swapped in a 14bolt with my front GM 60. And it looks a lot better. I had the 1970 open knuckle 44 with the HO52 and I have to say... It did look kind of goofy!
White K20 |
10-01-2015, 04:26 PM | #15 | |
Matching exactly to the smallest denominator is not what I'm after as much as I am keeping it narrow. If the Dodge axle keeps me under the body further I would go that route. To give you an idea of my madness: a GM axle with 3.73 is available to me for $750 shipped. A Dodge axle will be $500-600, plus the cost of gears and install ($200 gears, $150 bearing kit, $350 install), and depending on what axle I get it may not run with 3.73 so I would also have to buy a front differential (of course thats an excuse to get a powerlock in the front like I have in the rear - or maybe the trac lock). So all in all I will probably have to spend $1200-1300 MORE on top of the axle just to stay narrow. Like I said its an illness! |
10-01-2015, 10:12 PM | #16 |
It is. And the only cure is currently unavailable. Only treatment is badass parts.
10-02-2015, 09:29 AM | #17 |
Using Car-Part.com to find front 60's is kinda funny. Using craigslist or forums is people wanting infinity dollars. Car part is cheap but half them dont know where they stocked the parts. This will be an adventure.
10-02-2015, 10:02 AM | #18 |
What axle are you looking for? Local yard here has two Dodge 60s, both singles, but dunno ratios yet. One has typical lockouts, the other is the older style with external flanges.
10-03-2015, 12:20 PM | #19 |
Im pretty sure all 3/4 ton and 1 ton front axles are approx 69" wms-wms and the 1/2 tons are 67". Similarly the rears are all about 2" narrower than their matching front axle. So swapping the dana 60 into your 3/4 ton should look factory.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
10-03-2015, 01:16 PM | #20 |
I found a pair of 1992 Dodge Cummins axles. So I should be getting a 60 front that is 67.5 and a Dana 70 rear in the same width. Will post up once I measure them out. I guess the rear 60 I have is gonna get pulled.
10-04-2015, 09:25 AM | #21 |
Beware of the dana 61 with 3.08 gears. Not difficult to work with but may sway your decision.
10-04-2015, 10:23 PM | #22 | |
I have been told that they do that to increase turning radius. |
10-04-2015, 10:57 PM | #23 |
Yes I'm sure you have been on the western slope for 15+ years.
10-05-2015, 11:37 PM | #24 | |
I remember having this conversation with you Jason when I picked up my 14BFF with the discs. It couldn't have worked out more perfect though. The D60 rear that I had was a couple inches narrower than the 44 up front. The 14 bolt was a little wider. In the end, the rear is about 1/2" wider on each side. TBH, I really never noticed the difference in the first place but now my old eyes really can't see any difference! LOL. Sounds like the Dodge axles will work out just fine for you though. I always wondered about them. Post pics. Id really like to see how they go in!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-07-2015, 10:20 PM | #25 |
Will do. Before I swap in the Dodge front I would like to get a C30 steering box so I can do the crossover steering. Really don't mind the push pull steering I have but the crossover is less bumpy in the wheel! Also wouldn't mind doing the crossover along with high steer even though I don't go fourwheeling like that...just to get the tie rod up with the drag link.
