09-12-2003, 07:23 PM | #1 |
Play it Loud...
How much of a drop do I have?
When I got my truck, it was already lowered. I measured from the ground to the center of the fender and I got 27" in the front and 26 1/2" in the back. I only measured the drivers side, but I'm only looking for a rough estimate on what kind of drop I probably have...
Big Moe =-=-=-= 1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint. 1952 Chevy Pickup waiting to be brought back home! |
09-12-2003, 08:34 PM | #2 |
measure from the center of the wheel to fender. the measurement from the ground to fender will depend on your tire size.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
09-12-2003, 11:17 PM | #3 |
First of all, why is the back of your truck lower than the front? Anyways... Look at the spring hanger on the rear. That's what mounts the front of the rear leaf spring to the frame. If it's level with the frame, that's 2 inches right there. If the rear shackle, which mounts the rear of the leaf to the frame mount, is about 4 inches long, that's another 2 inches. The front is trickier due to different aftermarket spring heights, and spindle drops. By looking at the very small pic of your truck there, I'd guess it's a 5/7 drop, maybe 4/6 depending on your tires. Is there a "C-section" cut into the frame over the rear axle?
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive! |
09-12-2003, 11:52 PM | #4 |
Well, my truck fenderlips are all at 29" and I have a 3/5 drop with 28" tires...if that gives you any indication...
