Old 09-30-2015, 08:30 PM   #1
nsb29
nsb29's Avatar
ls 2 wireing
I have a ls2 w/6l8e from 09 G8 looking for wire diagram and pin diagram trying to do my own thanks Doug
nsb29 is offline   Reply With Quote
Old 10-15-2015, 08:44 AM   #2
nsb29
nsb29's Avatar
Re: ls 2 wireing
Originally Posted by nsb29 View Post
i have a ls2 w/6l8e from 09 g8 looking for wire diagram and pin diagram trying to do my own thanks doug
help
Old 10-15-2015, 10:23 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: ls 2 wireing
I am pretty new to the LS stuff so I'm not sure if anything at this link will help you or not....
http://lt1swap.com/geniv_harness.htm
LockDoc
Leon
Old 10-15-2015, 05:05 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: ls 2 wireing
Thats a great resource for wiring. I'd also suggest downloading a version of the GM Factory manuals for the donor. They are available online, however I can't link to them as they are technically copyright'd.
Before you get too far on the wiring tho, make sure you've made up your mind on the trans. The G8 auto's aren't as popular in swaps because of the goofy flange-thingy on the output. Its possible to use a variety of other trans, but it will affect your overal wiring picture. Just something to keep in the back of your mind if you haven't gotten that far yet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-18-2015, 11:54 AM   #5
nsb29
nsb29's Avatar
Re: ls 2 wireing
LockDoc
ben there got sum help he has no info on g8 only camaro
Old 10-18-2015, 11:59 AM   #6
nsb29
nsb29's Avatar
Re: ls 2 wireing
the trans flange has ben taken care of and can be found in my tread 6l80e drive shaft its the wiring thing now
Old 10-20-2015, 11:27 AM   #7
Hart_Rod
Hart_Rod's Avatar
Re: ls 2 wireing
Have you tried the G8 forums or LS1tech.com?
Hart_Rod is offline   Reply With Quote
Old 10-22-2015, 09:07 AM   #8
nsb29
nsb29's Avatar
Re: ls 2 wireing
Thanks for all the help have ben to all the places you all have recommend have most of it figured out, with lti swaps 2010 Camaro and sum printouts my sun got me from his work on the 09 g8 but where does the start wire from the ignition switch go ? the g8 has it going to the BCM not using the BCM I assumed it would go to the ECM but no one shows it Im also unclear on the speedometer wire coming from the TCM does it go to the ECM and thin to the speedometer ?
