Old 09-30-2015, 08:37 PM   #1
csdineley
csdineley's Avatar
Finally getting around to swapping 14 bolt semi to 14 bolt FF ?'s
Hello
This is a project I've been meaning to get to for years now. I'm moving out of state soon and I want to get this done before I leave. The 14bff is out of a suburban (I think it was an 86'). My 14bsf is stock for my 87' R20. I've ordered new U-bolts and plates and all the Brake parts. But my main question is the U joint. Will my stock U joint fit. Or do I need a conversion U joint and if so which one? I'm sure I read about this when I first started this but now I can't remember and can't seem to find it.
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's
csdineley is offline   Reply With Quote
Old 09-30-2015, 09:44 PM   #2
Ski-me
Ski-me's Avatar
Re: Finally getting around to swapping 14 bolt semi to 14 bolt FF ?'s
In stock form, I believe both use the same 1350 joint. Check and see if both yokes have the "secure tabs" on each side.
My 14SF has 1350 joints.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-01-2015, 01:23 AM   #3
csdineley
csdineley's Avatar
Thanks, I'll check in the morning.
