'64-66 tachometer
What tachometer can be adapted/retrofitted into '64-66 instrument cluster, right side?
What after market tach has been used with reproduction instrument decals? Got this thing out and apart, might as well fill the holes. Thanks, Fredthecat |
![]() Join Date: Jan 2011
Re: '64-66 tachometer
I have an older sun tach in mine that I pulled out the can. Almost a bolt in. Bosch is reproducing it now in a 8K model and I have been tempted to buy one and take it apart.
Jimmy ![]()
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 10-01-2015 at 08:31 AM. Reason: add |
Post Whore
![]() Join Date: Mar 2013
That tach only works for V8's according to All reproduction companies I've looked it up on. If you have a V8 that'll work fine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Aug 2013
i found a sun tach that was setup for a inline 6 and just took the shell off, oh it came with the box thing that can be used on 6 or 8cyl
of course it was nos and cheap!!! oh the box is call a transmitter...
Thanks for info.
Yeah, not so much $225. Need to find one I can adapt and install with reproduction decal set. Thank you, Fredthecat |
