Old 09-12-2003, 09:13 PM   #1
chucks70
'68 E-brakes
Does anybody have correct routing for E-brake cable on a '68 133" wheel base truck. Cab has cable that is long enough to go to a bracket underneath the seats like my '70. This frame does not have that bracket and this cable is no good. The chassis has a cable that goes through the frame right by the clutch rod but the way it is run doesn't look like it will reach the E-brake pedal. I know it should work but I don't know how to route it.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 09-12-2003, 09:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It has a pedal? It should be a hand brake.
If you have a pedal, then treat it like a 69 and get parts for a 69 one ton.
Old 09-12-2003, 09:50 PM   #3
jef5150
Inline 69
jef5150's Avatar
hope its the right one,,,,,,,,,,
i also have, p-20 ,p-30 ,c/k, but its a pain to scan them all and re-size,,,,if you need a different one let me know,,,,,,jeff
jef5150 is offline   Reply With Quote
Old 09-13-2003, 07:27 PM   #4
chucks70
Thanks for the diagram, might be able to shorten the route to brake pedal. Yeah it has a brake pedal not hand brake. Cab #s say it was from a '68 4X4. Who knows what parts are original or not over the last 30+ years. Trying to make some of what I have on hand work.
