Old 10-02-2015, 08:01 AM   #1
Tevon
4L80e
Hey everyone currently have a 350/TH400 in my truck and im swapping a 5.3, and 4l80e into it.
For a stock driveshaft to be used what do i use?
Btw the transmission is from a 1995 3500 truck.
Tevon is offline   Reply With Quote
Old 10-02-2015, 11:31 AM   #2
toddoky
Re: 4L80e
Does your TH400 have a short or long tail shaft?
toddoky is offline   Reply With Quote
Old 10-02-2015, 11:54 AM   #3
Tevon
Honestly have no idea this is what it looks like
Old 10-02-2015, 12:05 PM   #4
toddoky
Re: 4L80e
That is a typical long tail shaft truck version TH400, which is a few inches longer overall than a 4L80 case. You would have to have your driveshaft shortened if you wanted to leave the engine/trans mating plane in the stock location (otherwise know as 1" set-back). The only way you could use your stock driveshaft as-is, would be to mount your 5.3/4L80 combo forward by a few inches, which I wouldn't do personally.
Old 10-11-2015, 10:04 PM   #5
crazy longhorn
Fabricate till you "puke"
Re: 4L80e
I may have missed something in the mix....but my understanding , is that he is using the 4L80 trans. If that be the case, the shaft needs to be lengthened? If I ,missed the post, disreguard my reply. on your short bed truck (1 pc shaft), you can have a shaft built reasonably. Shove the yolk all in the trans, mark it with a sharpie, then pull it out 1", make another mark. At thi point (with the weight on the truck), on the wheels....measure from the center of the U joint spot on the trans yolk, to the center of the U joint on the rear diff. this should give you center to center on your U joints. Talk with the shop, doing the shaft, to be sure that your measure is on the same page, with them. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-13-2015, 01:30 PM   #6
toddoky
Re: 4L80e
Yes, the overall length of a 4L80 is shorter than a TH400 with the typical long truck extension housing, which means if you did an LS/4L80 swap into a squarebody originally equipped with a TH400 like the OP's and maintained the engine/transmission mounting plane in the stock location, you would have to lengthen the driveshaft. If the TH400 being taken out had a short 4" extension housing then you would have to shorten the driveshaft to work with the 4L80.
Old 10-13-2015, 07:12 PM   #7
crazy longhorn
Re: 4L80e
Thanks for the reply....it sounds like we are on the same page longhorn
Old 10-13-2015, 09:32 PM   #8
hugger6933
Re: 4L80e
The yolk for the T400 should work out for the 4L80E
hugger6933 is offline   Reply With Quote
