Old 10-02-2015, 10:57 AM   #1
C.20
C.20's Avatar
Need help center bore wheels
How's everyone doing I have a question about center bore I'm buying wheels it's a 1971 c20 with a 86 c20 rear end it's a 8x6.5 boy
Pattern the only thing I'm worried about is the center bore I don't want to buy 500$ wheels and they won't fit if someone can help me out i would apperciate it
C.20 is offline   Reply With Quote
Old 10-02-2015, 09:52 PM   #2
Mmorgan32
Mmorgan32's Avatar
Re: Need help center bore wheels
From what I understand most modern wheels are not hub centric meaning the lug nuts center the wheel not the hub so the bore on the new wheels might be bigger than your hub. I would measure your hubs and ask where ever you are buying them from what the center bore is or tell them what you have so they can give you options.
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 01-13-2016, 02:59 PM   #3
Super_Dave
Super_Dave's Avatar
They do make hub centering rings.
http://us.hubcentric-rings.com/why_h.../?src=intpopup
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 01-13-2016, 03:06 PM   #4
davepl
davepl's Avatar
I've used hub centering rings BUT I believe they only are for nut-centric wheels. Because they are plastic, they only serve any purpose while you're in the process of setting up the wheel and bolting it up.
It certainly can't -ride- on the ring because, as I said, it's made of plastic. So if the wheel actually relies on the hub for centering after it's bolted up, I think you need to check with the wheel manufacturer to be sure...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-13-2016, 04:49 PM   #5
Mike C
Mike C's Avatar
The 8 lug rims available in the aftermarket or the OEM's for that matter up until '98 with Ford and Until 2010 with GM should fit. Dodge will work until 2010 as well I think and maybe to present. Not sure if they have finally succomed to the metric pattern phenomena or not.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
