Old 10-02-2015, 11:22 AM   #1
68Stepbed
68Stepbed's Avatar
Lowering my sled questions.
I'm thinking of lowering my 05 GMC CC. I'll probably go mild like 2/4 or 3/4. I haven't been able to come up with an answer yet on this. Will I need to c-notch for a mild rear drop? At what point is a c-notch required?
Also, who makes the best lowering components?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-02-2015, 02:49 PM   #2
JRE
Re: Lowering my sled questions.
I think anything 4" or less you can run without a C notch.
JRE is offline   Reply With Quote
Old 10-03-2015, 08:23 PM   #3
grumpyolddog
I have a 2002 sierra 4 inches in the front and 5 in the rear no notch but the axle hit my left pipe on the left exhaust. No duals now bummer.
grumpyolddog is offline   Reply With Quote
Old 10-08-2015, 10:29 AM   #4
BTK
BTK's Avatar
Anything lower than 4" will require a C-notch. Although I would recommend skipping the 2/4 and going straight to 5/6" rear drop as the 4" drop is extremely stiff. I did the full flip kit on mine and am now 4/6 and it rides better than it did at stock height.
69 C10 Longbed- 406 c.i. SBC, 175 shot, 7.52 in an 1/8th.
BTK is offline   Reply With Quote
Old 01-04-2016, 11:24 AM   #5
solidaxel
solidaxel's Avatar
Anybody have a kit for the C notch, does the bed have to be removed on a 03?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-04-2016, 04:02 PM   #6
BTK
BTK's Avatar
I'd get the Mcgaughy bolt on kit, the DJM kits have a reputation to crack. If you have access to a rack you can get away with cutting it without removing the bed.
Old 01-04-2016, 04:32 PM   #7
solidaxel
solidaxel's Avatar
Thanks for the help
LS 3 4L70E
