Old 10-02-2015, 02:41 PM   #1
ShinyC10
Rattling rear end
My 86 short bed rattles so much when I hit any size bump. Sounds like something is loose but I have been under there a couple times and haven't found anything loose. Anyone else had this problem?
ShinyC10 is offline   Reply With Quote
Old 10-02-2015, 06:05 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: Rattling rear end
Mine makes a ton of noise to. I was thinking my bed was loose. Is your truck dropped? I was thinking it was bad shocks or I needed to take a leaf out of the rear.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 10-02-2015, 06:12 PM   #3
65standard
65standard's Avatar
Mine is the same. Found my noise, right spring front eyelet broke and one leaf also the left spring rear eyelet broke.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 10-02-2015, 06:13 PM   #4
ShinyC10
Yes it's dropped 5 up front and 7 in the back. It doesn't bottom out in the rear or anything. The bed is tightened down. The shocks are close to four years old?? But I got them at the same time as my front shocks and those are doing fine.
Old 10-02-2015, 06:21 PM   #5
ShinyC10
If that's the case, would I have to replace the set of leaf springs no?
Old 10-02-2015, 09:17 PM   #6
Jake Wade
Jake Wade's Avatar
Checked the tailgate?
Jake Wade is offline   Reply With Quote
Old 10-02-2015, 09:26 PM   #7
ShinyC10
I fixed the tail gait rattle a few months back but maybe I need to redo it
Old 10-02-2015, 10:53 PM   #8
Jake Wade
Jake Wade's Avatar
Other ideas, tailpipe, spare tire carrier, shocks, leafs, loose bumper brackets
Old 10-03-2015, 07:06 AM   #9
homemade87
Pop the tailgate off and make a run. The tailgate may seem good but when hits a bump it will bounce . Sure way to eliminate it .
homemade87 is offline   Reply With Quote
Old 10-03-2015, 09:08 AM   #10
tommy217xxx
I think mines in the tailgate b/c my gate doesn't fit very tight. What's the tailgate fix everyone's talking about.
TJ
80 Chevy c10 lwb
305/350
Old 10-03-2015, 11:50 AM   #11
ShinyC10
My "fix" was simple and worked well. I took mine off and wrapped those pegs with electrical tape to make them fit tighter in the holes so they didn't have any movement.
Old 10-03-2015, 11:53 AM   #12
ShinyC10
Sounds like a plan. I'll let y'all know how it goes
