![]() Join Date: Nov 2000
Lowering shock options
So I've been thinking of lowering my truck on a budget by cutting a coil on front and finding tj springs for the rear. As far as shocks do I HAVE to buy lowered shocks or are there options like installing shocks off a car or something like that? Thanks.
![]() Join Date: Sep 2006
Re: Lowering shock options
Summit has some choices for lowered shocks.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#3 | |
I would highly recommend looking around your local junkyard for Timbrens off an S-10 Blazer, or other truck with a towing package. You will have to trim them, but it makes life better to have them in place so you still retain a measure of safety when you bottom out (if you're heavily loaded)
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#4 | |
They ride a lot better than the blown out originals. I found them recommended in a bunch of posts.. but one thing that wasn't mentioned was the bolt diameter is smaller than the stock shocks which took some dealing with ( I reused the old hardware but that required a little grinding and welding..) For $20 a pop I'm pretty happy all the same.
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
Thanks for the info guys. I went ahead and cut 1 coil off the front and now the truck looks perfect. Not even going to bother with the rear. I drove it and it runs great. I could use some shorter shocks maybe but I didn't notice and issues. I definitely could use some newer shocks as these are the originals. Truck has 48k miles on it so they're not blown but are 60 years old lol.
Here's a pic.
![]() Join Date: Jan 2011
Truck looks good. You can run stock length front and back and have lots of choices. I am running the Belltech street performance on mine and really like the ride.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'm still learning.
Is "Ride Height" as the truck sits unloaded? So, if I didn't have any rear shocks, would the "Ride Height" measurement I need to take be from center of shock stud hole to center of shock stud hole?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
meowMEOWmeowMEOW
Yes, but shocks usually list a compression and extension length. You just need to make sure that your ride height is fairly well within those specs. So an 11" ride height would usually use a shock listed like "compressed 8, extended 13"...if that makes sense at all.
Just avoid getting a shock thats way too short or long. You won't want a shock thats 11" extended, if 11" is your ride height...or a shock thats 10" compressed on an 11" ride height. Both will be bad. It can get way more complicated than that, but thats the basic idea for most simple shocks.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I measured everything after installing 5" rear springs (TJs are too springy for me), and cutting 1 coil in the front. I like 'em down slightly in the rear.
I looked up all the commonly available at Kragen shocks, and used F150 fronts in the back on relocated mounts. I used stock chevys in the front and relocated the top mounts using the original rears mounts . Worked perfect! OK I admit it . I am a total cheap skate Rides real nice tho! W |
