Old 10-03-2015, 02:28 PM   #1
yossarian19
S10 hitch for 55-59 trucks?
I was looking around for vehicles with a 34" frame width.
I know the Chevy Venture hitch works on a TF truck, but I wanted something rated heavier.
The Crown Victoria hitch is a maybe, I know the front section is the same width as a TF but not sure about the rear.
The S10, I think, has the same rear frame width -- anyone looked at it any closer? Would be nice to put at least a 7500 lb hitch on the truck.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 10-03-2015, 04:28 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: S10 hitch for 55-59 trucks?
Use the U Haul receiver for the Chevy Venture and add side plates to mount it to the sides of the frame and add a tube going forward to a second cross member that is also plated to the sides of the frame rails.
This will spread the load over a longer portion of the truck frame.
It wouldn't hurt to box the frame rails also.
What are you planning to tow that you need this much receiver for ?
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 10-03-2015, 07:45 PM   #3
OrrieG
OrrieG's Avatar
I found a used Draw Tite Class 3 that mounts to the bottom of the frame. Rear most bolts were ok but front a problem. I just welded on some side plates to distribute the load along the frame. The receiver tucks right under the bumper.
OrrieG is offline   Reply With Quote
Old 10-03-2015, 07:49 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Nice pics Glen!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-03-2015, 08:53 PM   #5
mr48chev
mr48chev's Avatar
That last one comes under the heading of "will handle far more than the truck will".
You still have to stay within what the donor S-10 chassis was rated at for towing and that is probably some where between 3000 and 5500 lbs depending on what year and chassis.
My ongoing truck projects:
Old 10-04-2015, 12:17 AM   #6
G&R's57GMC
G&R's57GMC's Avatar
Originally Posted by Dan in Pasadena View Post
Nice pics Glen!
Thanks Dan.
To The O.P. The Venture receiver is rated at 3500# with 350# Tongue weight.
Besides the TF Frame is not robust enough for a 7500# trailer.
Glen & Jane's Rides
Old 10-04-2015, 12:37 AM   #7
yossarian19
Originally Posted by G&R's57GMC View Post
Thanks Dan.
You think? I hadn't even thought of the frame as a limiting factor.
I have an '04 Grand Cherokee, rated to 7500 lbs, that I would like to downsize. I'd like to be able to pull a project home, though, which leaves the truck. 3,500# doesn't cut it. 5,000# might but more would obviously be better.
"Over my head"
Old 10-04-2015, 12:43 AM   #8
G&R's57GMC
G&R's57GMC's Avatar
Ah ... This could be posable with the additions I mentioned above .
Just be sure the load on the trailer is balanced over the trailer axles.
Glen & Jane's Rides
