Old 10-03-2015, 04:22 PM   #1
68farmfresh
later model parts interchange???
Anybody here have knowledge of later model parts from say a 88-99 chevy full size truck working on 67-72 c10's and 20's?
For example, would front spindles and disc brakes from 88-99 2wd chevy trucks work on my 68?
68farmfresh is offline   Reply With Quote
Old 10-03-2015, 04:35 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: later model parts interchange???
Depends on if the control arms were relatively the same. So you could use the later model ball joints. You would also have to use the late model outer tie rod ends.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-03-2015, 06:31 PM   #3
hugger6933
Control arms are a no go. there was something about putting the spindles from the LD 3/4 ton and outside steering but you had to have 68 control arms for the bottom ball joint to fit and those that did do it could never get the alignment right. I had plans on using all that stuff to do a disc brake changeover cause I still have a full front suspension from a 95 LD 3/4 ton at the shop. I read about people not making it work right so I gave up on it maybe do a search 95 ld 3/4 ton front disc changeover
hugger6933 is offline   Reply With Quote
