Old 10-04-2015, 01:32 AM   #1
60_Apache
making my own 60-62 power steering adaptor
Hello everyone.
I've been looking for an adapter for attach the power steering box to 60-62 x-frame. Then there not much information like 63-66 frame.
So I decided to make one myself.
Let's see what happen.
60_Apache is offline   Reply With Quote
Old 10-04-2015, 08:07 AM   #2
uppster
Re: making my own 60-62 power steering adaptor
You could build your own, but Captainfab unit is sure nice and easy to install.
uppster is offline   Reply With Quote
Old 10-05-2015, 01:05 PM   #3
60_Apache
Manual steering box before and after remove from the truck.
The 3 bolts on the chassis indicate the holes where the manual box mounted to.
Old 10-05-2015, 01:24 PM   #4
RKS0069
RKS0069's Avatar
You can do it for sure! This is captainfabs plate FYI.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline   Reply With Quote
Old 10-05-2015, 01:24 PM   #5
60_Apache
I use the card board to draw 2 lines with 90 degree to each other.
One line is for steering shaft line and the other line for pitman shaft line.
Then I lay the old manual steering box on the card board.
Make sure steering shaft and pitman shaft are lined up with the line on the card board.
And mark where the pitman arm is.
Also mark 3 holes for the manual steering box.
Old 10-05-2015, 01:31 PM   #6
60_Apache
Then I do the same for Power steer box.
Power steering pitman arm is a bit shorter than manual steering pitman arm.
Old 10-05-2015, 01:38 PM   #7
60_Apache
Excellent! you did a great job. I like what you did.
I should have seen this before I did my own.
