Front drive shaft issues
I have searched, but could not find what I am looking for... My front drive shaft seems to be in pretty rough shape.... The shaft is two piece, where the two come together is very sloppy.... Can this be rebuilt, or can I buy a new one? I am assuming that all there is between the two are splines, or is there some sort of bearing on there that would tighten the two up? If I have to buy the two shafts, where can I get them? Thanks guys....
![]() Join Date: Oct 2005
Re: Front drive shaft issues
A drive shaft shop can rebuild it.
really not worth rebuilding it, especially if its worn where you describe.
better to spring for a brand new shaft and joints. it will cost more up front but it wont go through as many u joints and will not damage your axle and trnsfere case. go for a new one and be done with it |
the boat guy
Slip and stub can be replaced by a driveshaft shop. If your tube and weld yoke are in good shpe there's no need to get a new shaft.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
if if if, if this then that, if that then this,if if if
WTF is that suppose to mean? |
I guess it means nothing . best of luck rebuilding your drive shaft
the boat guy
He means there's a lot of ifs. Do you have a 4x4 or are you taking about the front piece of a 2 piece driveshaft? If you are talking about a 2 piece driveshaft there were two different. Styles used commonly refered to as hd and light duty, the hd shaft has a slip and stub where the shafts connect, the light duty has a bolt on yoke with splines but no slip. Either can be rebuilt easily by any driveline shop and balanced as an assembly.
