10-04-2015, 04:48 PM | #1 |
replacement Detent(TV) cable
I need a new detent cable for my 86 C20 5.7L,700r4. I have tried a universal cable from one of the big aftermarket trans stores and it was made very poorly. It wouldn't set when trying to perform the procedure, no ratchet. So I tried a Advance Auto one, the cable is so tight in the housing. It doesn't spring back when pulled.
NAPA ? Any idea's or are they still available at the dealership ? Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
10-05-2015, 07:56 AM | #2 |
Re: replacement Detent(TV) cable
I bought one from NAPA a year ago or so, and it worked fine.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
10-09-2015, 02:47 PM | #3 |
I found the GM replacement cable at JC Whitney. Hard to believe. Came in a ACDelco box part # 25515598 GM # 25515598 and the best thing of all it was under $20 dollars.
Ken
