Old 10-04-2015, 09:00 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Master cylinder pushrod questions.
I am removing the vacuum booster and master cylinder,
Going for a manual brakes master cylinder.
I know the pushrod is different, does anybody know how long of one I'll need.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 10-05-2015, 12:45 AM   #2
NJ C10 Guy
Re: Master cylinder pushrod questions.
I have a hydraulic clutch pedal setup with manual brakes sitting in my garage. I can take a measurement for you. Does the manual brake pedal take a different size pin for the pushrod than the power brake pedal?
NJ C10 Guy is offline   Reply With Quote
Old 10-05-2015, 12:48 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
I haven't taken it apart yet, waiting for the master cylinder to show up.
Was trying to collect parts up before I pull it apart.
Old 10-05-2015, 12:50 AM   #4
NJ C10 Guy
Ok. Pretty sure it is. Check post #3 in this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=527532
Old 10-05-2015, 01:33 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Yeah, I read that one while searching the board.
I was looking for a length, wondering if this will work.
http://www.mpbrakes.com/gm-adjustabl...ame=&limit=100
Old 10-09-2015, 10:11 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
How do I remove the push rod from the brake booster?
Old 10-09-2015, 11:55 PM   #7
68c10owner
68c10owner's Avatar
You shouldnt have to. There is a pushrod on the pedal that pushes into the booster against a second pushrod if I remember right.
Anthony
68c10owner is offline   Reply With Quote
Old 10-10-2015, 12:53 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Between the pedal and booster, I pulled the booster and master. And can't seem to get the pushrod out of the booster.
Old 10-10-2015, 12:57 AM   #9
68c10owner
68c10owner's Avatar
Take the pin out of the brake pedal. Should unscrew? Been a while since I had a system off.
Anthony
Old 10-10-2015, 01:08 AM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
The back half did, the front half or booster side feels like a clip or something.
But I'm understanding the power brake pushrod would be to short for a manual master cylinder, so the hunt continues.
Old 10-10-2015, 03:58 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Score! 1st truck at the pick N pull was a manual brakes.
Got the pushrod now to bleed the mess..
Old 10-10-2015, 10:48 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
It bled easy, has a great pedal.
The offending part.
Can't wait to drive it.
Old 10-16-2015, 07:04 PM   #13
wraprail
wraprail's Avatar
The offending part.
So which master are you using?
wraprail is offline   Reply With Quote
Old 10-16-2015, 08:10 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
That's the manual brake master cylinder push rod.
Found one in the 1st truck at the pick n pull.
