Old 10-04-2015, 09:01 PM   #1
TwinsSpeedShop
LS oil pan and laying frame
This next build is going to lay frame with LS/T56 combo. I've never ran anything but stock pans but I know this build will require it. Most have used the f body or cts-v pan but after some research, Holley has a pan that's even shorter and evenly priced. What is everyone running on these frames with LS.
TwinsSpeedShop is offline   Reply With Quote
Old 10-05-2015, 03:30 AM   #2
dwalt14
Re: LS oil pan and laying frame
mine isnt laying frame but i have an f body oil pan and it sits maybe 1/2-1 inch above my crossmember
dwalt14 is offline   Reply With Quote
Old 10-05-2015, 08:48 AM   #3
Hart_Rod
Hart_Rod's Avatar
Not sure about the Holley pan, but the Fbody pan works.
Hart_Rod is offline   Reply With Quote
Old 10-05-2015, 09:26 AM   #4
TwinsSpeedShop
Thanks, I was hoping you would chime in
Old 10-05-2015, 10:00 AM   #5
Hart_Rod
Hart_Rod's Avatar
, Let me know when you are ready for a set of ChubTubz!
Old 10-05-2015, 12:36 PM   #6
tinydb84
tinydb84's Avatar
I have an F body pan and lowered my motor mounts 2.5 inches and still clear the ground.
David
Instagram: myfabguy
Old 10-05-2015, 02:27 PM   #7
slowcpe
slowcpe's Avatar
I'm not laying frame but have the Holley pan sitting in the garage. It looks to be the thinnest pan out there.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-05-2015, 02:33 PM   #8
TwinsSpeedShop
By the numbers, it is the shortest pan out there
Old 10-05-2015, 03:31 PM   #9
boostedc10
boostedc10's Avatar
I am running the Holley 302-2 pan laying frame.
I only used it because I wanted a little more clearance up front. As for pan depth it measures about the same as the fbody at 5.5.
One thing I didnt like about the Holley pan is the windage tray has to be shortened in order to use it.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-05-2015, 08:02 PM   #10
mooseknuckles
mooseknuckles's Avatar
the holley pan is the same depth as an f-body pan and depending on which one you get, one has a different profile with more clearance up front.......you can buy a f-body pan for $250 from summit, the holley ones are another $100 more....and you can also get a killer satin black holley pan #302-2bk for $399
mooseknuckles is offline   Reply With Quote
Old 10-06-2015, 01:17 PM   #11
68Stepbed
68Stepbed's Avatar
Mine isn't laying frame, but if I were, I'd have the clearance with my F-body Pan. Of course, this is on a stock crossmember.
Difference in truck and F-body pans.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-06-2015, 06:40 PM   #12
TwinsSpeedShop
Thanks for the input guys. I ordered my f body pan kit for $307 shipped. That was everything needed to install it.
Old 10-06-2015, 08:23 PM   #13
crazy longhorn
Fabricate till you "puke"
On the cheap...GMPP hot rod pan/ pickup. Check Summit or Jegs, around 150 bones (pan , pickup & dip stick....gaskets & bolts included). Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-06-2015, 09:32 PM   #14
TwinsSpeedShop
I looked at that pan longhorn, it's only an inch shorter than the truck pan. The Holley and f body pans are 5.5 deep
Old 10-07-2015, 07:47 AM   #15
dec010974
dec010974's Avatar
I used the Holley 302-1 oil pan. I like it. from what I see, the f-body oil pan is a good buy. it definitely is cheaper than the Holley. the most expensive oil pan I bought was a regular, truck oil an paid some one to modify it. it leaked from some of the welds. that's how I ended up buying the Holley. advice, pay for what you need, cheaper.
dec010974 is offline   Reply With Quote
Old 10-15-2015, 06:19 PM   #16
crazy longhorn
My bad....a second look under my truck, says no it will not lay frame ! The pan hangs at the lowest spot about 3/4" below the stock engine cradle. For my app...(mild drop), It works well tho Longhorn
Old 10-21-2015, 09:02 PM   #17
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I posted quite a bit of info in this thread. Check it out. Holley pan all the way.
http://67-72chevytrucks.com/vboard/s...d.php?t=685258
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 10-30-2015, 10:18 AM   #18
lowlyfec10
where you at in easley? i might have to stop by next time i visit home in central
i'm running an oe fbody pan with cpp stands/sliders and it sits an inch or more above the factory crossmember. i'll be ordering a full dropmember kit next week so im sure it will still clear. the only thing with my setup that hangs below the frame currently is the 4l80e pan with the cpp trans member.
lowlyfec10 is offline   Reply With Quote
Old 10-30-2015, 08:37 PM   #19
TwinsSpeedShop
I'm building the frame in Greenville at a buddies place in cherrydale. I'm building a shop on my property in liberty in between six mile and liberty. If you head back to central on day shoot me a pm. We can meet up.
I ended with the fbody pan and it is clearing the drop member just mine. I'll be mounting the t56 next week.
Old 10-31-2015, 05:01 AM   #20
Cobalt964ruf
Cobalt964ruf's Avatar
the shortest oe oil pan is the ls2/3 gmpp road race wet sump pan. its only 4.25" tall
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 10-31-2015, 04:31 PM   #21
TwinsSpeedShop
That's good info. Hadn't come across that one in my research. Thanks for sharing
Old 11-02-2015, 03:56 AM   #22
Cobalt964ruf
no problem, I run them on my ls powered Porsche 911's. nice pans.
Old 11-02-2015, 03:58 AM   #23
Cobalt964ruf
if i remember correctly the gmpp part # is 12624617
Old 11-03-2015, 02:34 PM   #24
lowlyfec10
i'll be visiting home this weekend so i might have a lil free time saturday, but have to head back to atl sunday morning.
Old 11-04-2015, 10:40 PM   #25
TwinsSpeedShop
Well after mounting motor in drop member, the f body pan really doesn't fit. It is short enough but the sump is really to far forward. By the numbers the Holley pan is the best choice. I'm going to take some more measurements in the morning and order pan. If anyone needs an f body pan.... I got one !!
