10-04-2015, 09:58 PM | #1 |
Shocks
after getting everything bolted in and shocks on it is very stiff like it wont budge when pressing down on the frame, is this normal or do I have something bond up?
10-04-2015, 10:43 PM | #2 |
Re: Shocks
It will be without the weight of the body on the frame.
You can find me on Instagram @neveno_cten |
10-04-2015, 11:35 PM | #3 |
Re: Shocks
Some new shocks are REALLY stiff. It took ALL my weight(180 pounds) to compress my new ones.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-05-2015, 06:11 AM | #4 |
Re: Shocks
You are missing a couple of thousand pounds to help you. Till you get it pretty close to built wont move much. Like TJ said some shocks are a bit stiff by hand.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-05-2015, 10:15 PM | #5 |
Re: Shocks
Thanks guys!! Made me feel better.
10-08-2015, 03:41 AM | #6 |
Re: Shocks
Shocks are filled with gas. The stiffness you feel from trying to compress the shocks is only the gas pressure within the shocks. It's there to prevent the oil from foaming up/cavitating while driving. It is when the shocks are easy to compress you know there is an issue. All good.
