Old 10-05-2015, 06:57 AM   #1
chrismoore701
chrismoore701's Avatar
Step side gas tank filler necks
What are you guys using for gas tank filler necks on step sides? I thought I would just use a radiator hose that was a close fit, but after watching power block this morning, they recommended against that. Your thoughts.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 10-05-2015, 07:12 AM   #2
77 ChevySport
Re: Step side gas tank filler necks
chrismoore: LOL: AFAIK no one makes a filler hose for the 70's stepsides that will fit.
I been trying to find one for years. Also the 76/77 hoses are a little different from the 78/79's. Hard to believe that no one makes one. I'm still using my original. It's true that using a radiator hose is not advised. (Not made for fuel)
It you do a search on this board this topic has come up many times. Larry
77 ChevySport is offline   Reply With Quote
Old 10-05-2015, 09:24 PM   #3
chrismoore701
My dad cut my old ones off. So I am in dyer need
Chris
Old 10-05-2015, 09:50 PM   #4
chrismoore701
What about this?
http://www.classicindustries.com/pro...ts/152863.html
Chris
Old 10-05-2015, 10:02 PM   #5
NASTY-LSX
[QUOTE=chrismoore701;7331523]What about this?
http://www.classicindustries.com/pro...ts/152863.html[/QUOTE
this looks like a good idea!
NASTY-LSX is offline   Reply With Quote
Old 10-06-2015, 06:58 AM   #6
77 ChevySport
May be worth a try for a 78/79 but will not fit a 76/77 as I have tried. It comes out 2" short. The repro has a sharp turn in it that can not be straighten out. Picture below. Larry
Name:  77 Chevy Sport Pick Up 008.JPG
Old 10-06-2015, 09:15 AM   #7
Greenlee
Greenlee's Avatar
I put together a fleet side hose and a generic fuel filler hose from O'Reilly's using conduit that fit the inside diameter and hose clamps. Not an ideal solution, but I could not find the right hose.
Greenlee is offline   Reply With Quote
Old 10-06-2015, 12:58 PM   #8
ron350
ron350's Avatar
Larry what truck do you have.
My 75 step side has only a passenger side gas tank and the hose looks long like the one in your picture.
But where it bolts to the steel filler neck it is curved sharper than 90 like a candy cane.
Let me see is I can post a picture.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 10-06-2015, 03:13 PM   #9
77 ChevySport
ron350>I have a 1977 Stepside Shortbed. My hose does not look like yours.
It is longer w/o that sharp bend as noted in my picture. I have been told that the inlet hole to fuel is placed different in the 76/77's vs. 78/79's. How the 75fits in I don't know. Larry
Old 10-06-2015, 05:45 PM   #10
ron350
ron350's Avatar
Thanks Larry this is all interesting.
Old 10-07-2015, 06:08 PM   #11
tucsonjwt
If all you need is the rubber hose, then you can buy semi-flexible fuel hose of the correct inside diameter on Ebay, Amazon, and elsewhere. It is very expensive, but you can buy it by the inch. If you need the steel neck that attaches to the bed, then there is no such neck on the market - as was previously mentioned. I found some fuel filler hoses on a utility bed from an 80s square body in the junkyard that were in very good shape. So, you might check with truck equipment companies or look for an old utility bed in the junkyard.
tucsonjwt is offline   Reply With Quote
Old 10-08-2015, 01:10 AM   #12
lilpoindexter
lilpoindexter's Avatar
MY '78 short step smells like gasoline sometimes...i need to drop the tank and look at all the rubber lines, but i'm kind of scared of what i will find.
lilpoindexter is offline   Reply With Quote
Old 10-08-2015, 12:12 PM   #13
79sierra
79sierra's Avatar
This is a left side hose. I used it for my 79 stepside but had to cut it in the middle and use a coupler to rotate the top to match the filler neck. Then I had to cut off about an inch off the end. Still trying to find something for my vent hose.
79sierra is offline   Reply With Quote
Old 10-09-2015, 07:33 AM   #14
chrismoore701
Cant you just get the right size fuel line and use that? Why will that not work?
Chris
Old 10-09-2015, 10:52 AM   #15
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The reproductions are exact replicas of NOS original GM hosed. They are correct. Larry, When I look at your hose I can tell it's a stretched out original hose. Ron350, The reproduction should fit without issues. These are hoses we had reproduced and were copied exactly from NOS GM hoses like I stated. It is probable that the beds are shifted slight back or forward. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-09-2015, 01:36 PM   #16
77 ChevySport
FWIW: Upon checking my Chevrolet parts book there where several fuel hoses for the stepsides from 73-78 with DIFFERENT PARTS NUMBERS. This indicates to me that one hose DID NOT FIT ALL. The (77-78 only) with E62 (Stepside) took number 467574. It has long been discontinued from GM.
Maybe Wes's Hoses will work for you for certain years and I hope they do, but for my 77 which is totally original it did not. Larry
P.S. It should be interesting when the these hoses get out in the field and input starts coming back;will wait and see. Good Luck
Old 10-09-2015, 03:18 PM   #17
Classic Heartbeat
These hoses have been out in the field for more than 2 years. I just have only been wholesaling them. They come with a 5 year warranty. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 10-09-2015, 04:20 PM   #18
KrazyRay
KrazyRay's Avatar
The filler hole on the 77-78 stepside fenders are about 2" higher than the 73-76. I had every year stepside truck out here from 73-78 and measured them a while back.
KrazyRay is offline   Reply With Quote
Old 11-20-2019, 08:26 PM   #19
ron350
ron350's Avatar
77ChevySport
Did you ever find a longer passenger side stepside filler hose?
Old 11-21-2019, 08:44 AM   #20
chrismoore701
77ChevySport
Went back and looked at another thread I made
http://67-72chevytrucks.com/vboard/s...d.php?t=704049
This is the website for the last post. Check this place out. Good luck
https://www.gastankdepot.com/chevy-g...ler-necks.html
Chris
Chris
Old 11-21-2019, 10:42 AM   #21
77 ChevySport
77ChevySport
No; never did find one. I have gone on with other projects so I have not
tried too hard to find one. Truck is stored and still has original hose on.
Larry
Old 11-21-2019, 10:50 AM   #22
Ziegelsteinfaust
What about universal gas filler hose sections?
I used this in my van, but I had a gentle curve to deal with.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-21-2019, 07:58 PM   #23
ron350
ron350's Avatar
Thanks for the replies.
I will keep looking for a passengers side hose all I see are pictures of drivers side hoses.
Larrys picture above in post #6 is a passengers side hose.
Old 12-10-2019, 03:53 PM   #24
ron350
ron350's Avatar
Finally found a filler hose that works from a company called MTS. The first hose they sent me was for a drivers side gas tank so I sent it back and asked for the mirror image of the hose I was returning. They sent the correct hose for a passengers side even though the part # printed on the hose was for the drivers side.
It would appear they have the right and left side hoses mixed up but they insist I am the only person to have this problem.
If you look at the picture you can see the left side (drivers side) part # GMFH-5F printed on the hose connected to my right side (passengers side) gas tank. LOL
Old 12-10-2019, 09:24 PM   #25
dhenderz
Do you have a link or website for MTS? I cannot seem to locate them via Google.
dhenderz is offline   Reply With Quote
