GMC hood marker lights
How do I get these off?!
1961 crewcab
Re: GMC hood marker lights
usually you need to make a tool to do it with out breaking the lens, but since your lenses are gone, just get 2 flat blade screw drivers, and from the back you will see 4 tabs ( 2 top , 2 bottom) just push the two top tabs down with the screw drivers, and push it out, then you might need to do the same with the bottom 2.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: May 2007
http://67-72chevytrucks.com/vboard/s...=643920&page=2
start at post 34
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Awesome, thank you both!
