10-05-2015, 05:34 PM | #1 |
Dash gauge lights not working
Dash gauge lights don't work and never have since I bought the truck a year ago (replaced all bulbs but that didn't work). The turn signal indicators and hi-beam indicator lights up as does the heater panel light. Thinking either its a bad headlight switch or the ground on the printed circuit board on the back of the cluster is bad. Thoughts and advice would be greatly appreciated. If it is the printed circuit board, has anyone replaced them with the ones sold by Classic Industries??
1967 Chevy C10 Stepside SWB - 350/700r4 |
10-05-2015, 05:46 PM | #2 |
Hand Crafted C-10
Re: Dash gauge lights not working
Moving you to electrical. Good luck!
10-06-2015, 10:43 AM | #3 | |
78K & 79C Jimmys
You can sometimes see problems,when taking it out. PO may have reached up to replace bulbs then some paths break off and get twisted up, off the board. I use crazy glue,to reattach copper to board.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-06-2015, 01:37 PM | #4 |
before you start part swapping, check for power at the headlight switch for the dash lights
then start chasing the power to the bulbs, if it does end up at the ground, i'd ground the bulbs separately rather than change the board, assuming everything else works
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
